Timing belt #836670 09/18/07 04:22 AM
carook Offline OP
Whats best and worst scenario if timing belt brakes on 3.0 6 cylinder engine.
Re: Timing belt [Re: carook] #836671 09/18/07 04:26 AM
kewlynx Offline
Best: It's not an interference engine
Worst: Yer wallet for a tow truck, esp if you don't have the knowledge to fix it yerself
**ubi apis- ibi salus**
Re: Timing belt [Re: kewlynx] #836672 09/19/07 08:27 PM
P
Pat4x4 Offline
not always will it clear.. You can still bend a valve if there is alot of carbon build up..
Re: Timing belt [Re: carook] #836673 09/20/07 03:13 AM
O
oldsub86 Offline
I am also told that the belt shreds can wrap around the idlers so bad that you will have to replace them too.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: Timing belt [Re: oldsub86] #836674 09/20/07 05:00 AM
OOP'S Offline
Randy
If you are going that far into the engine it is recommend that you change the idler pulleys and the water pump also!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Timing belt [Re: carook] #836675 09/20/07 05:04 AM
kewlynx Offline
Give this a read; will ballpark you.
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Re: Timing belt [Re: kewlynx] #836676 09/26/07 11:51 PM
Stevie Offline
Holy Crap! After looking at that engine fix, I feel so good owning the 20R! <img src="/forums/images/graemlins/wink.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6125 MB (Peak: 0.6899 MB) Data Comp: Off Server Time: 2026-11-16 01:31:14 UTC
