Re: new found flex........ [Re: dirtcrazy] #836898 09/27/07 11:02 PM
logansportage Offline
That is sick flex. Almost as good as Dave's.
I'd like to see the RTI numbers from a 20 degree ramp on both your's and Daves to see who wins.
Re: new found flex........ [Re: dirtcrazy] #836899 09/28/07 04:13 AM
KIAFREEKROB Offline
Flexing out good in the rear = unfortunatly the front is gunna limit your wheelin' abilities in the rocks & ruts. I wonder if a softer spring up front with a spacer for ride height would work? VS: The SAS conversion? I know that the Rokia needs rear bumpstops to stop the rear flex & force the front to flex better & also not to kill the 1/4 panels. With the rear 1/4 eliptic, it is so flexy it needs to be stopped & make the front work a little harder = pressure can work in your favor sometimes. As for your setup with the front IFS Ya dont have alot of options - unfortunatly.
Ant other thoughts of how he can gain some front flex without goin SAS?
Heres Rokia maxed out in the rear W/O bumpstops = the 1/4 panels are what is stopping the tires = not good but still in the shakedown stage.
FYI: 2002 2 door still only 17,250 miles on it.
[img][image]http://img.photobucket.com/albums/v336/rockfreek/Rk%20Drg%20Rcs/DSC01605.jpg[/img][/image]
[img][image]http://img.photobucket.com/albums/v336/rockfreek/Rk%20Drg%20Rcs/DSC01603.jpg[/img][/image]
Why go around? When You can go over!
Re: new found flex........ [Re: logansportage] #836900 09/28/07 05:54 PM
Dave Scott Offline
um, maybe like mine about 7 years ago....
but nothing like mine NOW....
Re: new found flex........ [Re: Dave Scott] #836901 09/29/07 07:10 AM
A
Adskia Offline OP
your truck is just nuts dave.........i love how much flex you have now.......looks the goods hey........
well i have a few ideas for the front ........new custom made top and bottom arms.......and subaru struts modified to take the kia bottom......but will post pics as i do it hey.......secret squirrel stuff..... <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
have to wait a bit........
THE POWER TO SUPRISE.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6087 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-13 10:52:53 UTC
