Page 3 of 3 1 2 3
Re: Diesel Ranger [Re: Smeez] #837444 02/04/08 11:39 PM
david85 Offline
Will an upgraded intake and exhaust prevent a blown head gasket from increased fuel consumption by allowing the engine to breath more?
I really don't have an answer for that, as you already know, there is very little info out there on these engines. My advice would be to get a pyro, and boost gauge, from what little I've been able to find, the safe max is 15 PSI, but the stock blowoff valve is set to 12 psi I think. Anything to help a diesel breath better is a good thing, so opening things up will hurt nothing and might help control EGTs too. I might try to cross reference an ARP head stud that fits, because as of right now, stock head bolts are all there is. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Diesel Ranger [Re: Smeez] #837445 02/05/08 12:03 AM
david85 Offline
I know this is a dodge article, but the diesel ranger uses the same basic bosch injector pump.
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
I would advise increasing the fuel in 1/4 turn increments or less, the fuel screw is very sensitive.
Re: Diesel Ranger [Re: Smeez] #837446 02/05/08 02:53 AM
8
89Diesel Offline
On the diagram posted above, I turned up the "smoke" and the "power" screws a full turn each. I tried a 1/4 on both but it didnt do anything.(pump was maybe detuned pretty bad) I'm the only one who drives this truck, so, I watch pretty close what I do with the pedal. I can turn the tires into 3rd gear, but, I dont drive it that way. I am waitin on guages from Dakota Digital, so I can see what exactly its doing.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6001 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-11-14 02:49:30 UTC
