Front end rattle #837537 09/23/07 06:00 PM
Trooper-san Offline OP
My Trooper, the '89 2.6, has a front end rattle, and has had for quite awhile. I've looked and can't find anything loose, so I'm coming here once again for suggestions.
Rattle may not be the exact term I want. It's somewhere between a clink and a clank when I go over a bump. The bump can be a small as a Bot's Dot, the little reflective things they glue down the middle of the street in places. It sounds sort of like a small bolt bouncing inside a pretty solid housing. I'm fairly sure its coming from the front driver's side wheel area.
I've opened the front hubs to look at the infamous c-clip, and think its alright. See the picture.
Front Hub, driver's side
Did I go far enough into the hub, or is there another possibility farther in?
I'd really like to fix this. Its worrisome having an unknown rattle. Anyone have suggestions or opinions?
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: Front end rattle [Re: Trooper-san] #837538 09/23/07 07:34 PM
Smiley Offline
Maybe a Body Mount Bolt?
I've got a couple on the Rodeo that rattle pretty bad.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Front end rattle [Re: Smiley] #837539 09/23/07 09:32 PM
JLEMOND Offline
CHECK THE SHOCK MOUNTS , THEY WILL CLUNK LIKE CRAZY ,ESP IF THEY ARE STILL THE ORIG PARTS, JERRY
Re: Front end rattle [Re: JLEMOND] #837540 09/24/07 06:52 AM
Smiley, aren't the body mount bolts insulated with rubber doughnuts or something similar? What you're suggesting would mean that that rubber mount is completely gone. Possible?
Jerry, A loose shock mount makes a thunk sound. What I have is a definite clink or a clank. It's metal on metal, with nothing to insulate the sound. It sounds almost, in my imagination, like a nut loose in the bell housing.
This Trooper is my daily driver. There is no apparent problem with the exception of the clank when I hit certain bumps.
1989 Trooper, 2.6
1989 Trooper, 2.8
My Photos
Re: Front end rattle [Re: Trooper-san] #837541 09/24/07 08:15 AM
Jeff Mason Offline
auto hubs or manual hubs? I had superwinch hubs on my 88 trooper and they ALWAYS made rattling noises over even the smallest of bumps. It used to drive me crazy. (so I traded it for an Amigo <img src="/forums/images/graemlins/smile.gif" alt="" />)
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: Front end rattle [Re: Trooper-san] #837542 09/24/07 02:00 PM
Smiley Offline
Nah...
In my case the rubber is still there; it's just that a couple of the bolts are loose enough that they have room to slide up and down (and rattle -- rather loudly at times).
Re: Front end rattle [Re: Smiley] #837543 09/27/07 09:40 PM
I pulled the front shock today, driver's side. There's no sign on noise or rattle in the shock. Top and bottom mounting were tight. I have KYB hight pressure. It went back on.
The hubs are Superwinch. For the longest time they were absolutely quiet, no rattle. So, if by chance it is the hubs, they need attention. Still waiting for an answer whether the clip shown in the picture is the one which has given so many people problems.
Where are the body mount bolts located? My manual doesn't address that issue.
While I had the front wheel off and the Trooper on stands, I noticed that the hub has just the slightest bit of wiggle movement. I can lift it just enough to tell that it has moved. It makes just enough noise to be heard, but its not a klink.
Still looking.
Ken
1989 Trooper, 2.6
1989 Trooper, 2.8
My Photos
Re: Front end rattle [Re: Trooper-san] #837544 09/27/07 10:24 PM
BigSwede Offline
Just because the shock mounts were tight doesn't necessarily mean they were tight enough...hard to say from here though.
Serenity now!
Re: Front end rattle [Re: BigSwede] #837545 09/28/07 01:26 AM
ISueYou Offline
Your infamous C-clip looks a-ok to me
Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: Front end rattle [Re: Trooper-san] #837546 09/28/07 03:27 AM
Jeff Mason Offline
I'm still leaning to the hubs. Try this - find a 'known' stretch of street where there are cracks and bumps that will help your trooper make the noise that you hear. Drive down the street in 2wd and notice how much rattle there is. Now lock in the hubs and drive down the street again. If the noise is gone, it means there is free-play in your superwinch hubs when they are unlocked.
I'm tellin' ya, my Superwinches were quiet for a while, then started rattling up a storm after a while. When they were locked in, no rattle...
Jeff Mason
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-21 16:36:54 UTC
