Page 1 of 5 1 2 3 4 5
np231 #837902 09/24/07 11:15 PM
Mitsulvr Offline OP
I was wondering if the np 231 swap is just as doable in an 89 3.0 auto? If it is, have the seal isues been solved yet? I've done as much reading as I could today but have not found the answers.
Thanks in advance
Eric
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: np231 [Re: Mitsulvr] #837903 09/24/07 11:38 PM
LandRaider Offline
yes <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: np231 [Re: Mitsulvr] #837904 09/25/07 12:17 AM
NathanC Offline
Holy cow! I wouldn't even call the seal an issue. Get a 23 spline "medium" length shaft if you can find it. Worst case, get a long spline and cut a bit off the end of the shaft.
The seal is easy. Measure the OD of the seal, measure the OD of the t-case input shaft and that will tell you the ID of the new seal. Go to an industrial bearing supplier and give him those specs and find one the same width as the old one. If you can't measure the stuff, bring the parts in and have them measure them for you!
Worry about making new driveshafts and a new t-case shifter. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: np231 [Re: NathanC] #837905 09/25/07 03:51 AM
Mitsulvr Offline OP
Thanks guys. I never thought of that about the seals. One more question, Is there an easy way to tell what shaft the t-case has?
Eric Wegerich
Re: np231 [Re: Mitsulvr] #837906 09/25/07 11:36 AM
NathanC Offline
Not really. Here's a couple links to help, but realize there really is no rule for the input shaft.
Novak Conversions
Here's another one that sort of helps: Drivetrain.com
Scroll through the list for Jeep vehicles.
The most important thing is that you have to verify the length of the input shaft as well as count the splines for yourself. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Mighty Max
Re: np231 [Re: NathanC] #837907 09/25/07 12:29 PM
Y
yankneck696 Offline
This won't work for an 89 5 speed, right?
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: np231 [Re: NathanC] #837908 09/25/07 02:19 PM
PHIL_ Offline
Thanks Nathan. I'll have to help him all I can on this one, since we are talking about the truck formerly known as Betsy III! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: np231 [Re: Mitsulvr] #837909 09/25/07 08:28 PM
ForcedAir_Montero Offline
So who's actually completed this and running a 231?
I've lost track of this and kind of dropped the ball when we lost Matt aka Wyleone.
My case and new input shaft are still sitting here....
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: np231 [Re: ForcedAir_Montero] #837910 09/25/07 10:05 PM
Mitsulvr Offline OP
I've found three 231's to play with so we shall see. Although it looks like my 2.85's may be coming back now as well so now I'm not sure. <img src="/forums/images/graemlins/frown.gif" alt="" /> But I'll try to fit one either way just to see for everyone.
Eric Wegerich
Re: np231 [Re: ForcedAir_Montero] #837911 09/26/07 12:48 AM
NathanC Offline
I'm running two of them in a row. <img src="/forums/images/graemlins/smile.gif" alt="" />
No one to my knowledge has done it with a Gen1. I posted some pics a while back showing one held up to a KM148.
'88 Mighty Max
PHP: 7.4.33 Page Time: 1.789s Queries: 16 (0.005s) Memory: 0.6398 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-22 07:23:38 UTC
