91 rodeo rear axle/gears #838338 09/27/07 12:47 PM
L
lowflying90 Offline OP
i found a 91 rodeo that the gears are shot in. what vehicles have a rear end that will interchange with this? the trucks? amigos? troopers? the guy said they are 4.30 gears. how do i know what is in the vehicles without tearing it apart at the junkyard to find one that will work?
thanks,
jeff
Re: 91 rodeo rear axle/gears [Re: lowflying90] #838339 09/27/07 01:58 PM
RobG Offline
I assume you're looking for a complete axle replacement? since swapping only the gears requires a pretty high level of skill.
If he's got the 3.1GM engine, the rear axle is a GM corp 10-bolt (not to be confused with the Isuzu corp 10/12 bolt). Being a GM made axle, its actually pretty common and parts of readily available as GM used the same axle under many different vehicles.
if you don't know about the site www.car-parts.com, definitely check that out and you can source a replacement junkyard axle for relatively cheap.
-Rob
PS... what's shot about the gears? did he grenade them? gears don't typically "wear out" if installed correctly... if there is indeed failure, its usually pretty catostraphic.
Re: 91 rodeo rear axle/gears [Re: RobG] #838340 09/27/07 02:13 PM
mlclark Offline
Isuzu Moderator
I've heard of a few of the GM 10-bolts that just seem to eat their spider and side gears. It causes great havoc and is almost impossible to correct without a full rebuild, which is much more $$ than that axle is worth. Finding another is a good route of action.
Michael
Re: 91 rodeo rear axle/gears [Re: RobG] #838341 09/27/07 05:02 PM
L
-Rob
i'm unsure about what is wrong with the gears. he just said they are shot. on that www.car-parts.com website......... are those numbers that are listed for rear axles part of the vin number?
if so if i find out the vin of the rodeo will i be able to match it up with the vin of a truck or amigo or something so i can determine which one i need?
Re: 91 rodeo rear axle/gears [Re: lowflying90] #838342 09/27/07 06:06 PM
lttlbddy Offline
FYI - The Rodeo was the only Isuzu that used the GM 10-bolt.
A few people have swapped an Isuzu 12-bolt in place of the 10-bolt with relatively little in the way of mods.
If you are looking for a GM 10-bolt, look for Rodeos or other GM products. I'm not sure how the car-parts site works, sorry.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6739 MB) Data Comp: Off Server Time: 2026-06-21 09:38:11 UTC
