rear window does not work with tailgate key
#839181
10/01/07 07:00 PM
I have a 1987 Toyota 4Runner in which the window does not work using the key in the tailgate. The window works fine with the toggle switch in the center console.
Can someone steer me in the right direction as to what the issue might be? Does the same relay run the window motor from both the toggle switch and tailgate key?
Any help would be appreciated.
Thanks, Gregg
Re: rear window does not work with tailgate key
[Re: Gregg]
#839182
10/01/07 07:09 PM
[Re: 4Crawler]
#839183
10/02/07 02:13 AM
I actually already took the panel off and checked out all the rear window connectors etc. The connector to the key switch is firmly in place with no broken wires.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-06-23 19:42:43 UTCValid HTML 5 and Valid CSS
