Front Caliper Piston will not budge on my 89 #839377 10/02/07 12:36 PM
PatrickS Offline OP
Anyone have any idea?
Cannot press the piston back in.
Pad is still in.
No amount of pressure including c clamp helps.
Have also drained part of the fluid from the line.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: Front Caliper Piston will not budge on my 89 [Re: PatrickS] #839378 10/02/07 01:03 PM
hazy_daze Offline
Sounds like it's cock-eyed in the bore.
Re: Front Caliper Piston will not budge on my 89 [Re: hazy_daze] #839379 10/02/07 01:13 PM
PatrickS Offline OP
cock-eyed in the bore?
I am getting a little cock-eyed in the head.
How can I check and fix it?
Hate to be such a bore.
Re: Front Caliper Piston will not budge on my 89 [Re: PatrickS] #839380 10/02/07 01:15 PM
hazy_daze Offline
Can you replace the entire caliper? (parts availability question) Once it gets cocked in the bore, the damage is pretty much done.
Re: Front Caliper Piston will not budge on my 89 [Re: hazy_daze] #839381 10/02/07 01:18 PM
PatrickS Offline OP
Yes, but first I have to learn how to say cock-eyed in the bore in German.
I was afraid that was the answer.
Re: Front Caliper Piston will not budge on my 89 [Re: PatrickS] #839382 10/02/07 01:58 PM
hazy_daze Offline
der Kolben wird in der langweiligen Angelegenheit gekr³mmt
Clear as mud now? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Front Caliper Piston will not budge on my 89 [Re: hazy_daze] #839383 10/02/07 02:19 PM
PatrickS Offline OP
Absolut sprachlos!!!!
Re: Front Caliper Piston will not budge on my 89 [Re: hazy_daze] #839384 10/02/07 02:19 PM
PHIL_ Offline
I had a seized caliper a while back, and couldn't get new calipers very quickly, so I rebuilt mine - it was a PITA, but I did get the piston out - I used a BIG c-clamp, and also used the pressure in the system to eventually force the piston out of the caliper - if you go this route, make sure you have new seals/wipers to replace the old ones, and lots of patience.
Re: Front Caliper Piston will not budge on my 89 [Re: PHIL_] #839385 10/02/07 06:04 PM
Blow it out with pedal pressure. No other method can apply that much force. And it will make a mess....
K-D sells a couple of caliper piston presses. One is just a plate to seat against the caliper with a screw-in pressure screw, and the other anchors the same, but applies pressure like a caulking gun with a squeeze handle and a "ratcheting" pressure rod. I really like the second one. About $40 at NAPA.
Re: Front Caliper Piston will not budge on my 89 [Re: fasteddy] #839386 10/02/07 07:17 PM
powerRam50 Offline
that is why i just spend the money on loaded calipers.then i dont have to worry about any of that.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6316 MB (Peak: 0.7379 MB) Data Comp: Off Server Time: 2026-07-15 21:43:14 UTC
