tie rod collar/sleeve
#839770
10/04/07 11:56 AM
I need a tie rod collar/sleeve that is a bit shorter than the factory spec. My wheel needs aligned inward more, and the collar has no more threads left to adjust the wheel in! Does anyone no where I can get a sleeve for my 97 t100 sr5?
Re: tie rod collar/sleeve
[Re: fugitive4x4]
#839771
10/04/07 04:19 PM
Napa usually has them in stock, but if it's that far out I's suspect you need new rod ends more than new sleeves.
~Adam  96 T100: D44, lockers and stuff
[Re: fugitive4x4]
#839772
10/04/07 04:41 PM
Toyota Moderator
What I've done is cut the sleeve down a bit, as well as the tie rod end(s). You sometimes need to do this if you've got a lift kit.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5908 MB (Peak: 0.6439 MB) Data Comp: Off Server Time: 2026-06-24 19:25:45 UTCValid HTML 5 and Valid CSS
