keep blowing light fuses #840190 10/07/07 06:55 AM
snowrodeo Offline OP
my 97 rodeo 3.2 had a blown fuse for panel/tail lights. went thru everything and found the two front orange corner marker light bulbs were dead. for some reason this kept blowing the fuse when i turned them on. replaced the bulbs and was all good for a week. now the fuse has blown again. haven't had time to check the bulbs again but obviously something is causing this. any thoughts? found nothing on this in search mode. electricity is voodo black magic as far as i'm concerned. <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> (and don't anyone tell me it's just like water flowing through pipes! <img src="/forums/images/graemlins/lol.gif" alt="" />) TIA
97Rodeo Rancho9ks/Aisins/3.2L SOHC/M1 only
Proper Prior Planning Prevents P*ss-Poor Performance--Maj. R.T.Spooner USMC(Ret.)
Re: keep blowing light fuses [Re: snowrodeo] #840191 10/07/07 08:17 AM
Jim_Paget Offline
A common cause of this problem is a short somewhere in your trailer wiring harness.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: keep blowing light fuses [Re: Jim_Paget] #840192 10/08/07 04:56 AM
thanks! i didn't know where to start looking. i think my pigtail might be old and giving me trouble. this is why i like this website so much. you da man! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: keep blowing light fuses [Re: snowrodeo] #840193 10/08/07 04:25 PM
BigSwede Offline
Trailer harness makes sense, I blew that same fuse repeatedly on a trip while towing an old camper in the rain...one (more than one, actually <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ) of the lights on the camper was broken and water got in and kept shorting out the system.
Serenity now!
Re: keep blowing light fuses [Re: BigSwede] #840194 10/08/07 05:24 PM
Gizzy42 Offline
Ok, its like electrons flowing through copper. Better? LOL
Trailer harness is usually the main cause of stuff. Not just the pig tail but the converter box as well. Disconnect or replace all of it to start. If that doesnt work then start disconnecting things one at a time till the problem goes away.
Do you have an aftermarket stereo? The factory one uses wires from the lighting circuits. If the aftermarket one doesnt (mine doesnt) those wires might be loose and shorting on something.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-06-05 08:23:10 UTC
