reoccurin code........ #840381 10/08/07 10:12 AM
A
Adskia Offline OP
have a code that after a few weeks it comes back to haunt me
code number: P1123
any help wuld be great....
cheers Ads <img src="/forums/images/graemlins/kewl.gif" alt="" />
THE POWER TO SUPRISE.
Re: reoccurin code........ [Re: Adskia] #840382 10/08/07 12:26 PM
Axe Man Offline
Kia Moderator Emeritus
Are you sure you got the right numbers?
P1123 is not a valid code, at least according to my FSM which covers 1998-2000 North American Sportages.
Nearest code is P1121 then it jumps to P1307.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: reoccurin code........ [Re: Axe Man] #840383 10/08/07 03:03 PM
Iron Offline
This is what the CD that came with my scanner says about code P1123
OBDII P1123 Fuel Trim Additive, System Too Rich
PRIMARY COMPONENT:
Air/Fuel Control System
SECONDARY SENSOR(S):
Mass Air Flow (MAF) Sensor
Throttle Position (TP) Sensor
Intake Air Temperature (IAT) Sensor
Engine Coolant Temperature (ECT) Sensor
Oxygen Sensors
FAILURE CONDITIONS
If the air/fuel mixture at idle is too rich for more than 30 seconds during two back-to-back trips, this code will be set and the Malfunction Indicator Light (MIL) will be turned on.
Details:
The code will be triggered if the following conditions are met:
Long term fuel trim value (additive) is less than -0.75 ms (-15% to -20%) for 30 seconds or more
Engine speed is less than 880 RPM )
Mass air flow rate is less than 6.1 g/s
Engine coolant temperature is greater than 158?F (70?C)
Engine in closed loop operation
No canister purge occurring
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: reoccurin code........ [Re: Iron] #840384 10/08/07 05:34 PM
Axe Man Offline
OBD-II trouble codes beginning with P1XXX are manufacturer specific codes. They CAN have different meanings. I checked around and Kia does not use P1123. See this...
http://www.obd-codes.com/trouble_codes/kia/
But there IS the possibility that OZ Sportages are different.
Re: reoccurin code........ [Re: Axe Man] #840385 10/09/07 09:52 PM
A
Adskia Offline OP
yeh guys that is the number.........and thanks heaps for the explanation of it iron........sounds right to as i went wheelin the other day and it sucked a gut load of mud.........had to clean the airflow meter ......so that explains it .....cleaned it and drove it .....the code appeared again and i cleared it .....and it hsnt come back......thanks heaps guys.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-06-09 13:57:18 UTC
