Overheating Problem! Please Help!! #840386 10/08/07 03:11 PM
highvan Offline OP
Hey All,
I have a serious overheating problem w/ my Toyota truck. Ive replaced the water pump and the thermostat and it still bubbles up! It runs okay if I leave the thermostat out but then I dont have heat in the truck....and I still have to add water a couple times a week to the radiator.....
Please help! <img src="/forums/images/graemlins/confused.gif" alt="" />
www.warrencountyimports.com
Calling all creative people, could be an easy $30, no joke! http://carandturcktalk.mywowbb.com/forum11/7.html
Re: Overheating Problem! Please Help!! [Re: highvan] #840387 10/08/07 04:41 PM
4Crawler Offline
Might be due to a bad head gasket. To test for that condition, pressure test the cooling system, look for a pressure rise with the engine revving. Or do a chemical test on the coolant:
- http://www.supras.org.nz/techinfo/bhg.htm
Re: Overheating Problem! Please Help!! [Re: highvan] #840388 10/09/07 03:09 AM
busterz Offline
Pull and check your spark plugs. See if one or more are "white" - if they are, you're probably leaking coolant into those cylinders. Then do leak down test and watch those cylinders closely- I'm doing my 3.0L fot the second time right now (dealer did it 1st time under warranty about 100,000 miles ago). Good luck.
'90 Toyota Xcab 4x4- sold it
'84 RX7 GS
'03 Silverado SS
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5935 MB (Peak: 0.6474 MB) Data Comp: Off Server Time: 2026-06-24 23:03:07 UTC
