Re: 22r carb problem [Re: Chompy] #840435 10/09/07 06:07 AM
daveowen Offline OP
yes sir, i sure am
Re: 22r carb problem [Re: daveowen] #840436 10/09/07 07:15 AM
ArbitraryNotion Offline
my FSM says it needs to be connected to the L terminal on the Alternator. What this means is that the choke thermostat (your red wire) needs to be connected so it only gets power while the engine is running. You should be fine if you just hook it up to switched power. Just remember, it will heat up if you put the key to the ACC position and it might not start right if you leave it that way for 10 mins. Not a big deal but something to keep in mind.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5945 MB (Peak: 0.6428 MB) Data Comp: Off Server Time: 2026-11-17 11:30:30 UTC
