Re: Operating fluids [Re: eleet] #840579 10/10/07 09:49 PM
MRT100 Offline OP
Thanks to all who responded to this question.
Erik,
You state replace fluids about 30k.
30k WOULD take about 3 years for me.
So, am I ok to assume?
replace every fluid (except oil, synthetic - 5K)
in about 30 K
Eleet,
Again thanks for your post.
Why use Syntec 10w-40 ??
Thanks to all
Re: Operating fluids [Re: MRT100] #840580 10/11/07 12:54 PM
E
eleet Offline
Sometimes syntec cheaper than mobil, they are both very good oils - I've used both in one engine I've had for a very long time and it shows no wear on the valvetrain.
There is an article about oil on carbibles.com.
97 T100 4x4
97 328i
95 540i restoration project
Re: LUBRICANTS for T100 [Re: Honger] #840581 10/15/07 02:17 AM
speedlever Offline
Chassis and Hubs
Mobil1 synthetic (aggravates the snot out of me how the stuff seperates and oozes out of my grease gun)
Me too. So I switched from Mobil 1 syn grease back to Kendall SuperBlu grease for the driveline (11 zerks).
--speedy
White '98 T100 SR5 4x4 ExCab Auto - wrecked.
2008 Honda Ridgeline RTS replaced the T100.
Re: LUBRICANTS for T100 [Re: MRT100] #840582 10/31/07 02:00 AM
adam Offline
It's Synchromax (not Synchromesh) High Perf. MT Fluid. I swapped it into both center boxes last Friday. I was not enthused by the grit in the drain pan when I emptied the transmission, but it seems to be a really nice oil after driving it a few hundred miles.
Even with age and wear, shifting is smoother through the 5 and in and out of 4wd. It pulls 80 pretty easily again. The only disconcerting thing is that there isn't a weight listing on the bottle and is recommended for vehicles that use ATF as well as weighted and unweighted motor oils. It pours like a 75/90. Their site probably gives an equivalent, but smoother shifting and better power delivery seem to sell it for me.
~Adam
Re: LUBRICANTS for T100 [Re: adam] #840583 11/01/07 06:31 PM
MRT100 Offline OP
Ooo Great! More choices.
So IT is Redline VERSUS Royal Purple.
Which is better?? Equal may be?
I just put Redline MT-90 into my T100 manual trans.
Planning on putting same MT-90 into transfer case.
Planning on putting Redline 75W90 to both differentials.
NOT sure about 75W90NS eleet mention earlier (no friction modifiers).
How do I check the type of differentials: conventional or limited-slip?
As I mentioned above IÆm set on Redline at this time.
The problem is there is no Redline product on the shelf around my location (Western Mass).
And Royal Purple IS available.
I have found local store able to order Redline for me.
For example: 1 qt of MT-90 about $15.00
Royal Purple: 1 qt of Synchromax $12.59 in local NAPA.
So you would say stick to Royal Purple.
BUT, I have found this http://www.morethantires.com/Redline_Oil.html
Every qt about $9.95 with about $8.00 for shipping.
When if I buying large qty (4 qt for MT and transfer, 6 qt for both diff) IÆm adding less then a buck/qt.
Now for the last:
Owner manual recommends for Differential:
Front (oil viscosity)
SAE 75W-90
Rear
Above û(minus)18 Celsius
SAE 90
Am I still OK with Redline 75W90 for rear?
Thanks
Re: LUBRICANTS for T100 [Re: MRT100] #840584 11/01/07 09:16 PM
adam Offline
I would say I used Royal Purple because it was on the shelf, and I tend to buy locally as much as possible. I have not had good luck shipping small quantities of fluids up here, especially in the winter.
I have heard good things about RP, but not specifically from Toyota owners. So far, so good. I imagine it is comparable to the Redline. It advertises that its components are kinder to soft metals (brass synchros) than garden variety 75/90, which is the selling point of Redline as I understand.
You're fine with 75/90 in the differentials.
~Adam
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6162 MB (Peak: 0.6872 MB) Data Comp: Off Server Time: 2026-06-24 08:51:05 UTC
