Re: Is there any benefit to an SAS on a 2WD yota? [Re: subliminaltrips] #840989 10/14/07 09:40 PM
sindersblue Offline OP
id just run leaves up front and link the rear or leaves all the way around. you could link it later when budget permits.
Remember that a 2 arm system will change caster and drive shaft angles as it cycles
Yeah, you're both right.
It's probably way more complicated than I think. I'll just keep it simple for now.
Any ideas on what leaf springs would be good?
I have access to some stock YJ leafs, though I think the're weak, and have lots of good Yota leafs on hand.
If you were doing it what would you do?
Thanks, Dan
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project
87 Turbo Truck, Boost Controller, otherwise stock... for now.
86 Turbo 4Runner, Project
Re: Is there any benefit to an SAS on a 2WD yota? [Re: sindersblue] #840990 10/15/07 02:15 AM
4Crawler Offline
Stock rear springs work well up front:
http://www.4crawler.com/4x4/4R_suspension-III.shtml#Front
Re: Is there any benefit to an SAS on a 2WD yota? [Re: 4Crawler] #840991 10/15/07 04:08 AM
subliminaltrips Offline
i think the 2wd leaves are the same as the ones 4 crawler used too.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6032 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-06-07 00:52:02 UTC
