NPR Bellhousing pattern #841345 10/13/07 06:46 PM
EVguy Offline OP
It's been a while since I posted here, mostly because my two diesel engine swaps have been running flawlesly.
I'm on to the next one and would like to bolt a NV4500 5 speed up to a Isuzu HF1 engine. Does anyone know if this is a standard SAE bolt pattern?
Thanks
Randy
Isuzu 4JB1-TC diesel / Jeep Grand Cherokee conversion
http://www.canev.com/Jeep.html
Isuzu 4HF1 Diesel / 99 Dakota 4X4 conversion
http://www.canev.com/Dakota.html
Re: NPR Bellhousing pattern [Re: EVguy] #841346 10/17/07 07:13 AM
Dougal Offline
I can't speak for the HF engine, but the B series automotive engines were not SAE pattern, the bolt spacing around the bottom is not consistent where the SAE patterns are.
However the industrial engines do look like SAE, but I don't know anyone who's measured one up.
Re: NPR Bellhousing pattern [Re: Dougal] #841347 10/23/07 12:48 AM
OutfitBoss Offline
Randy those are awesome conversions, thanks for letting us see them. That is great advice on your pages too.
"It took way more time (they always do) than I had hoped and way more involved. I would not recommend anyone attempting this unless they have lots of mechanical and electrical experience."
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: NPR Bellhousing pattern [Re: EVguy] #841348 10/24/07 12:16 AM
JLEMOND Offline
HI RANDY , DOUGAL IS CORRECT THE AUTOMOTIVE VERSION OF THOSE ENGS OR RATHER TRUCK VERSIONS DID NOT USE TH E ASE PATTERN, THE INDUSTRIAL ENGS DID , HOWEVER ON ALLMOST ALL OF THE BELLHOUSING WHERE THE LARGE TRANSMISSION FRONT BELL REGISTERS IN THE BELLHOUSING THE REGISTER DIA IS THE SAME AS AN SAE , ONLY THE BOLT HOLES DONT LINE UP, JUST SET THE BELL IN THERE AND REDRILL THEM, I JUST CRUSHED TWO COMPLETE 4HK1 ENGS THAT WERE BRAND NEW AND COMPLETE ,FOR ISUZU , I ALLMOST CRIED , WHEN THE BIG MAGNET HAMMER CAME DOWN ON THEM ,, THEY WERE THE ORIGINAL PROTO TYPE ENGS AND HAD A LOT OF HAND MADE PARTS ON THEM THAT WERE A ONE OF A KIND AND COULD NOT BE REPLACED , THESE THINGS EVEN HAD THE STARTERS AND ALT AND IONJ PUMPS ON THEM ,ONE WAS A MECHANICAL PUMP AND TH E OTHER WAS THE COMMON RAIL TYPE . ALONG WITH 2 OF THE BIG 6 HK SERIES MOTORS , THE 4 ENGS WEIGHED 4600 LBS AND THER E WAS A LOT OF ALUNINUM THERE . JERRY
Re: NPR Bellhousing pattern [Re: JLEMOND] #841349 11/11/07 10:59 PM
EVguy Offline OP
I might try and find just the NPR bell housing and adapt it to the NV4500. This is what I did with the Jeep and it worked very well. That way I keep the NPR clutch and release brg and only have to worry about trany input shaft spline mating up to the Isuzu clutch disc.
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.013s) Memory: 0.6056 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-11-04 20:43:02 UTC
