O2 Sensor #841821 10/16/07 02:46 PM
L
Littlewhitepup Offline OP
My o2 sensor light bulb was not there. When I replaced it the bulb is on. I guy I bought it from said he replaced the sensor and it looks new. Well just in case I went and bought one. I put it in and the light is still on. Is there something I have to do after putting it in? or is there something else I need to check?
Thanks
Re: O2 Sensor [Re: Littlewhitepup] #841822 10/16/07 11:28 PM
lttlbddy Offline
What year truck are we talking about?
The 2.3/2.6 motors (at least in the 89-94 Amigos) have an eccentric gear that turns the light on and off. It rotates once every 90,000 miles.
You need to move a screw from one hole to another to shut the light off. Here are some pages from the manual to shot the process. I think my page numbers are mixed up.
O2 Sensor
Re: O2 Sensor [Re: lttlbddy] #841823 10/17/07 03:40 AM
L
Its a 92 2.3 2wd pickup
Is all that still the same? If so I will try it in the morning
Re: O2 Sensor [Re: Littlewhitepup] #841824 10/17/07 03:46 AM
Jim_Paget Offline
I am not sure what the drill is on your rig. As Steve indicated, on an Amigo, you move a screw. On a similar vintage Trooper there is a slide switch on the back of the panel. In either case, the two accomplish the same thing.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: O2 Sensor [Re: Jim_Paget] #841825 10/18/07 12:04 AM
L
Yep thats what is was. I had to change the screw over. Thanks for the help.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6033 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-06-10 06:23:10 UTC
