1996 and newer taco.....
#842444
10/19/07 07:35 AM
howzit everyone. i read somewhere that the 1996 and newer tacos 4x4 rr axle has factory e-lockers. is this true? and has anyone considered putting that under a 1st gen truck? would it work? i'm asking cuz i have 83 4x4 and would like to try if doable. Thanks!!!
Re: 1996 and newer taco.....
[Re: superv43]
#842446
10/19/07 08:53 PM
thanks for reply. i browsed that article a while back but thought it was too much work. so my thoughts are would you be able to swap out the differential assy as a whole? would spring perch line-up, i guess the output flange would have to be re-drilled or changed...???
[Re: flyinhawaiian]
#842447
10/19/07 08:56 PM
Toyota Moderator
The axle will bolt right in. The brake stuff (e-brake and brake lines) is on opposite sides, but that can be fixed.
And yes, on a 1st gen, you'd have to redrill the driveshaft flange.
The Tacoma axle is also about 5" wider but the perch width is the same.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6036 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-06-13 13:53:19 UTCValid HTML 5 and Valid CSS
