89 D50 swap
#842652
10/20/07 03:27 PM
Well, I'm finally taking the plunge. I've got an '89 D50 4x4 with a 2.6 5spd, that I'm dropping in an '85 2.3TD from a Ranger. Just taking the gasser out today, the diesel should be here Tuesday. I'm in Regina Sask. Bought the engine from a wrecker by Edmonton Alberta (sight unseen, but I think I can trust the guy <img src="/forums/images/graemlins/kewl.gif" alt="" />). Should be a fun project, so I guess I'll have to break out the camera.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: 89 D50 swap
[Re: 89Diesel]
#842653
10/21/07 05:38 AM
If you have good luck with the engine, could you source one for me???
I've been looking for ever....
Re: 89 D50 swap
[Re: 88D50]
#842654
10/21/07 06:31 AM
Re: 89 D50 swap
[Re: 89Diesel]
#842655
10/21/07 06:38 AM
I think I've got a "little" cleaning up to do...<img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ![[Linked Image]](http://img98.imageshack.us/img98/5495/036ss3.jpg)
Re: 89 D50 swap
[Re: 89Diesel]
#842656
10/22/07 01:44 AM
That makes three 2.6 gas to 2.3 diesel conversions under way. There's another thread with a Montero diesel conversion and a Mighty Max as well. Both 4D55T's were pulled from diesel Rangers.
Pmontero
Re: 89 D50 swap
[Re: pmontero]
#842657
10/22/07 05:21 AM
if somebody ever hits my pajero and writes it off....my 2.5 4D56 is definetly going in a ram 50, I want a lowrider diesel truck.
Re: 89 D50 swap
[Re: 89Diesel]
#842658
10/22/07 04:05 PM
I think I've got a "little" cleaning up to do...<img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Is the input bearing and seal toast on that tranny?
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
Re: 89 D50 swap
[Re: NathanC]
#842659
10/22/07 10:45 PM
Naw, rear seal on the engine was leaking, that and the vibration was caused by the rear main gone. The guy I bought the truck from said the engine was just rebuilt (aerosol overhaul <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) cracked head and all. I should have quit when I was behind... but I went thru 3 heads (plus $70 head bolts each time <img src="/forums/images/graemlins/scared.gif" alt="" />) from the the wreckers before finally sealing the last one with Irontite. I did buy a brand new head(not reman) w/new valves installed, 3 weeks ago, but didn't get a chance to put it on <img src="/forums/images/graemlins/rolleyes.gif" alt="" />. Looks all pretty and shiny sittin on the shelf!
Re: 89 D50 swap
[Re: 89Diesel]
#842660
10/25/07 08:03 AM
Well the diesel showed up yesterday. Looks pretty good! I guess the fun(expense) now starts. I picked up a new pressure plate, pilot bearing, thowout bearing and clutch for the D50 to replace the Ford. Now I have to round up some serpentine pullies for the A/C, Dodge Alt, and P/S pump. Due to lack of available parts, I'll fab up some motor mounts, A/C bracket and exhaust. Have to hit the local wreckers for an intake of some sort and swap out the oilpan with the old 2.6
I sure hope this is worth it in the end. The expense list is growing <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Engine-$1400 Shipping-$151 Clutch, P/P-$167 Engine crane-$170 (sold mine a couple years ago after swearing I was done swapping engines in old trucks! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) New Lincoln Mig-$499 on sale from $749 (just my luck, someone stole my other one over the weekend, right before I needed it for this project <img src="/forums/images/graemlins/angry.gif" alt="" />) Let's see...The truck was $2700 6 mths ago New tires-$400 Heads, gaskets, bolts (3 before I found one without a crack!)-$250 Sceamin Deal on brand new head w/valves-$250 (these suckers retail for $585 w/out valves but never I never got a chance to install it) I'll put a new water pump, starter and alt on it if this things actually runs, just because I'm gettin good at blowin money on stuff I don't really need.
So far $6000, give or take, on an 18 year old truck <img src="/forums/images/graemlins/scared.gif" alt="" />...and counting <img src="/forums/images/graemlins/lol.gif" alt="" />
At least I won't have to as myself "What was I THINKING" The answer is obvious... "I WASNT!!!"
Oh well, it's probably only half what I'll have to spend to appease the wife-gods when she finds out... <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 89 D50 swap
[Re: 89Diesel]
#842661
10/26/07 12:48 AM
I wonder if anybody can look into a front 1/2 cut pajero or something with a 4D56...1/2 cut cars start around $2000 and go up from there depending on what it is, If you could find a 1/2 cut pajero diesel from japan, it might work out around the same price...everything you'll need will be there
