Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842880 10/24/07 04:09 AM
kewlynx Offline
Yep, L43, but the reference to cross checking parts compatibility is about the clutch plate.
Your other terrific reference here is www.marlincrawler.com in Fresno. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 20R from 2WD swap into 4WD, help!!! [Re: kewlynx] #842881 10/24/07 04:10 AM
cokeslingin Offline OP
What are the pros and cons (if any cons) to mating a 5 speed to my 20R? Yeah, go ahead and call me a NOOB, I can take it! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842882 10/24/07 04:33 AM
kewlynx Offline
The L43 was rather weak as a 4 speed; it's also got a side shift, which none of the rest of the trannys have. The L52 was modded by Marlincrawler as an L54; I believe the gear ratios are on his site.
No cons really; the 22R wasn't that much bigger. In fact, the Japanese 21R-U was a bolt-on to the L52, so I think you'll be okay with the G or W series. An R series would be more desireable if you want to upgrade to a 22R or even a 2.7L later on.
You still haven't mentioned what you're putting this into, other than a 4x4. If it's past an 83, you'll have some crossmember work to do with the L-tranny, if dropped in all together.
Re: 20R from 2WD swap into 4WD, help!!! [Re: kewlynx] #842883 10/24/07 09:41 PM
1980 Toyota 4WD. Needs a lot of work. The guy I bought it from had put a 3 in. body lift and is rolling on 35's. As far as I know it still has stock ring and pinion in it. Bigger, better, badder upgrades planned for the future!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6079 MB (Peak: 0.6640 MB) Data Comp: Off Server Time: 2026-06-23 00:44:37 UTC
