Page 3 of 4 1 2 3 4
Re: Cold Air Box Fab and Install [Re: hlhneast] #843164 10/25/07 05:35 PM
SavageSun4x4 Offline OP
Don, just like Fred said, try not to let it bother ya. I took some serious hard knocks when I first started posting (and still do occaisonally) but I have found that overall the folks here are good. I try very hard to not swap insults. Some of the comments here were off base and the poster had misread what you stated on your website. From what I have seen, yer not sayin yer way is the best nor is it the only way, its just the way you did it to yours. I thought yer fabbing of the CAI was neet even if I am not gonna do it to mine. It would give someone who decides he wants to mod his ride ideas on how to do his own and maybe save some bucks in the process. Face it, if someone decides to mod something, he's gonna do it no matter what others advise him to do or whether its bad for his ride or not. I do believe that having cooler air entering yer engine is better for performance. There are very few places on a Jeep that allow this to happen and any filter that is exposed is likely to suck something up your pride and joy will not digest well. IMHO Cold Air Intakes have no place off road at all for this reason. And I do actually have an open chrome air filter assembly sitting on top of my 304. But come huntin season and when I know I am goin into wet, soupy, or overly dusty environs, the stock assembly will go back on. The only way I see your Jeep getting honest cold air is with a cowl induction of some kind or maybe a snorkel. AMC-DC has done the best it could short of that. Using the headlight bucket area sans bezel as an induction port was a pretty good idea except at night with the headlight burning maybe, lol. I understand painting the area black was to help with aesthetics after removing the bezel, not to improve air flow. I would have used screamin red or sonic blue if that was the case <img src="/forums/images/graemlins/lol.gif" alt="" /> Anyway, I found your website informative and nicely done. We welcome you to the board and keep the info coming, just dont try to promote something you are selling on this forum, there is another place for that on this site. Take care! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Thank you...got nothing for sale here, just a retired old geezer who after 40+ years of Jeeps is not getting to spend quality time working on it.
Not sure when you were last at the site but I just posted the pics and write up of "Part II (same page).
Lots of folks encounter cooling issues. I live out in the desert and when I moved here from Dallas several years ago I thought I knew hot! They KNOW HOT out here. Toss in a Jeep with AC and a supercharger that is passing HOT engine oil thru the SC and back down into the pan and in from of my AC/radiator I also have a intercooler.
Albeit my Jeep NEVER overheated it did run the ragged edge of being too hot and leaving little margin for getting much hotter.
I worked to solve the problem and was able to do so using OEM parts. BUT what I could not solve was my problem with pre-detonation. And in the hottest time of the year I had pre-det at any speed above about 45. In fact I could not even drive on the freeway with 91-92 octane fuel.
What I knew was I needed a cooler air charge to the engine. Trying lots of approaches I finally solved it.
Install Chrysler LeBaron hood vents
Removed headlight trim rings
Install OEM 7 blade fan and HD clutch
This solved my heat and pre-det issues, even when hauling my M101 military trailer at highway speeds.
But I knew I had found something with getting the engine bay cooler which resulted in a normal temp running engine and a BETTER running engine...NO pre-det!
I then spent a lot of time researching various air intake systems looking for a way to get direct outside air into the intake with out the drawbacks.
The opening paragraphs of the web page 2-3 describe what I discovered. This lead to fabbing up a "box" that I could mold to fit behind the headlight bucket. I picked a "Trash can" because of its cost and mold-ability.
I now run 87 octane year round, something the SC folks will say you cannot do. Why can I? Cooler outside air down the throat of the intake system. And I have a better running Jeep to boot.
I know it works because it is about the same as the OEM system Jeep has used...ref: para 2-3 of the aforementioned webpage on "Trash Air" <img src="/forums/images/graemlins/cheers.gif" alt="" />
Had a few folks on here bothered to read those 2 very short paragraphs and look at the pics, they too would have known <img src="/forums/images/graemlins/kewl.gif" alt="" />
Further reading and ref:
http://www.savagesun4x4.com/oem_7-blade_tj_fanclutch_in.html
http://www.savagesun4x4.com/jeep_cooling_electric_vs_me.html
http://www.savagesun4x4.com/hood_vents_for_tj.html
Thank you and enjoy <img src="/forums/images/graemlins/patriot.gif" alt="" />
Don
Scottsdale, AZ
Re: Cold Air Box Fab and Install [Re: jstritec] #843165 10/25/07 05:41 PM
wow
good post
laughed my ass off
y'all need to lighten up
big jim been around a bit since maybe the hoover administration?? the roosevelt i'd bet
ya gotta live and learn, but if you're askin for opinions, ya gotta take what you get.
welcome to a free forum, these guys got experience, and i think all BJ is sayin is its a bullshit mod,
so when i drop five grand on a supercharge for the cj, maybe i'll save 50 bucks on an intake.
whoop de do
josh
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
LOL thanks for the comments.
HEY, you think that after dropping $5k on a SC I got ducats left over for anything fancy? Did you see how I raised my Jeep seats or keep my console and floorboards cooler from the heat...can you say low-buck:
http://www.savagesun4x4.com/jeep_seatriser_install.html
Don
Scottsdale, AZ
Re: Cold Air Box Fab and Install [Re: SavageSun4x4] #843166 10/25/07 08:18 PM
2000Trooper Offline
I checked out the link of your writeup from the first post and quickly looked at the pictures on the right hand side to see what you had done. I then read the text to see the specifics of the installation.
I have to admit, I didn't see the supercharger until you mentioned it. I then went back and sure enough it was there. Its not the easiest thing to see unless your looking for it.
Jaime
Re: Cold Air Box Fab and Install [Re: 2000Trooper] #843167 10/25/07 09:06 PM
Brown81CJ5 Offline
Hey Savage, do you have an oil cooler on that rig? That would help dramatically in enigne heat reduction. Almost necesary with boost.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Cold Air Box Fab and Install [Re: SavageSun4x4] #843168 10/25/07 09:30 PM
F
Fred Blackstone Offline
"I was simply responding to what someone else had said." That is called schilling. Stand on your own and for GAWD sake don't listen to the rantings of BJ.
Don, a shill is the deceitful supportive statisfied customer during a business related swindle. Hangers-on maybe close to the word you were seeking. <img src="/forums/images/graemlins/ignore.gif" alt="" /> See, I got this affinity for language ... even though I struggle with it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Cold Air Box Fab and Install [Re: Brown81CJ5] #843169 10/25/07 09:58 PM
Hey Jamie, it was not the focal point of the post and I certainly did not mention it...the focus was how do I get some cooler air into the intake. It does get hot here, it was 93 yesterday...but its a dry heat <img src="/forums/images/graemlins/kewl.gif" alt="" />
Don
Scottsdale, AZ
Re: Cold Air Box Fab and Install [Re: Brown81CJ5] #843170 10/25/07 10:00 PM
No, I don't and yep, you are right on that, I have looked at them at lot and am going back and forth between installing one and going with a sealed SC unit...I'll post something in the future on this.
Don
Scottsdale, AZ
Re: Cold Air Box Fab and Install [Re: Fred Blackstone] #843171 10/25/07 10:06 PM
I go deeper into the definitions (see below). Hangers on, err maybe, how about peanut gallery?
To act as a shill.
v.tr.
1. To act as a shill for (a deceitful enterprise).
2. To lure (a person) into a swindle.
Noun 1. shill - a decoy who acts as an enthusiastic customer in order to stimulate the participation of others
decoy, steerer - a beguiler who leads someone into danger (usually as part of a plot)
Verb 1. shill - act as a shill; "The shill bid for the expensive carpet during the auction in order to drive the price up"
cozen, deceive, delude, lead on - be false to; be dishonest with [color:"blue"] [/color] <img src="/forums/images/graemlins/cheers.gif" alt="" />
Don
Scottsdale, AZ
Re: Cold Air Box Fab and Install [Re: SavageSun4x4] #843172 10/25/07 11:07 PM
cuervo25 Offline
all in all I enjoyed you writeups, they are interesting and imformitive. However wouldnt use a [email]K@N[/email] filter due to the oil coating,I know what that did to my regular tb,ias and so on. I would hate to see what it could do to a $5k unit. I remember from the box it did say the holes was larger to allow more air(miniscule to our eyes),but still It does allow more fine dirt and the coating to make its way in.I know arizona has pleanty of dust. I also remember that it said that the dirtier it gets the better it works. Which leaves me to wonder why use a filter that works better when dirty,than a filter that has about the same restricion in the first place.
I was thinking maybe try one of the large cone filters from a ford truck, or the cyl. shaped ones from the chevy trailblazer. that would be interesting to see a comparison on those 3 filters. As I said good write ups just something that I wouldn't do.
Just for referance reasons I been through all sorts of conditions with the jeep in VA when I lived there dry, dusty,muddy,&snow I finally trashed my [email]K@N[/email] when I moved to jersey because I got tired of removing the TB to clean it
Re: Cold Air Box Fab and Install [Re: cuervo25] #843173 10/26/07 12:28 AM
Thank you
That is not K&N, it is some other brand as I remember. It is a K&N filter sock which I use out here in the desert due to the fine dust that gets kicked up as you drive.
But as of yesterday I have left the cone filter completely behind and gone to a Purlator in the OEM air box.
new pics and writeup: http://www.savagesun4x4.com/cold_air_fab_and_install.html
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Don
Scottsdale, AZ
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6556 MB (Peak: 0.8030 MB) Data Comp: Off Server Time: 2026-06-24 08:16:19 UTC
