Re: Head gasket blown 2500 miles after complete rebuild
[Re: toyomorph]
#843427
11/16/07 04:05 AM
We'll I cant be 100% sure that it would be ok, I noticed daylight through mine when I sat the head on the block with no gasket, and I can promise you that mine would have had problems, because theres no way it could have compressed the gasket around the #1 cylinder. Are you getting water and oil mixed after a rebuild, and did you notice any kind of step between the two surfaces?
89 yota pickup 22RE 261C cam Tanny / engine rebuilt after 256K Head machined to RV street spec(EB's)
[Re: toyomorph]
#843428
11/16/07 11:02 PM
Might ask Ted - he's probably run into motors where that mistake was made before.
Personally, I think that's quite likely... But you wont' know for sure until you pull it and see if the gasket is blown or get some indication of how the water/oil is getting in.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#843429
11/17/07 03:07 AM
actually, I'm not getting water in oil at all. I'm losing a little coolant at a steady but very slow rate. And also it uses oil regularly. When the nose is pointed down at steeper angles it smokes. Weird problem and probably won't be able to tell what is going on until I open it up.
canyon country explorer 1993 4x PUP
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5985 MB (Peak: 0.6513 MB) Data Comp: Off Server Time: 2026-07-09 19:31:06 UTCValid HTML 5 and Valid CSS
