Any comments on this Class III Hitch #844068 10/28/07 06:34 PM
rrolsbe Offline OP
I am in the market for a "Class III" hitch for my 1996 Xcab 4x4. Anyone have any comments regarding the purchase of this hitch from this web site "See link below", price, performance and cost etc.. Other recommendation also welcome.
http://www.hitch-web.com/proDescrip.asp?ProductCode=324804&OID=8#
Thanks Much In Advance
Regards
Ron
1996 Toyota Tacoma XCab 4x4 3.4L
ARB Bullbar & Warn Winch
Super Spring progressive leaf springs
SuperBumper in rear 2" receiver
Moderator Marks factory Bilstein shocks/Front Coils
Albuquerque, NM
Re: Any comments on this Class III Hitch [Re: rrolsbe] #844069 10/29/07 12:05 AM
W
Whizkidder Offline
Looks like a good hitch -- probably stronger than OEM Toyota model, which has the side plates bolted to the cross tube instead of welded.
I believe you may be able to get the same Curt hitch for a few less $ on Ebay, depending on where you live (shipping cost...)
Good Luck.
Re: Any comments on this Class III Hitch [Re: Whizkidder] #844070 10/29/07 05:06 PM
Seattlegti Offline
I have Curt on my 98 Cherokee. It's heavy and stout as can be. FYI mine didn't come with mounting hardware but I bought it "open box" item for $50.
Re: Any comments on this Class III Hitch [Re: rrolsbe] #844071 10/31/07 02:59 PM
rrolsbe Offline OP
Thanks for the replies.
I purchased from realtruck.com
This was a slightly better price than I found on EBAY and the realtruck site was easy navigate.
Curt Class 3 Hitch Ball Mount w/ Right Angle Design - Fits 2" x 2" Receivers (#CU-D-6RA)
Black Powder Coat - Style 2 (HS:1" Drop:4" Rise:2" Length:10 1/4" GTW:6,000/TW600lbs)
1 $40.99 $40.99
Curt Class 3 Rear Receiver Hitch - 2" x 2" Receiver Black Powder Coat (#CU-13013)
Toyota Tacoma (1995 - 2004) ALL (Note:Z)
Curt Class 3 Rear Hitches 10% OFF Today Only
Please Note: Due to size or shipping requirements, this item has an Additional Handling Fee of $7.95. 1 $167.35 $167.35
-$16.74
Sub Total: $191.60
Please Note: some items due to size or weight may require an additional oversize handling charge.
Shipping Method 5-7 Day Ground Shipping: $16.07
Handling: $7.95
Tax (0%): $0.00
Web Promo Shopzilla 10% Order Discount on Performance Coupon Code: SJ921 Savings: -$19.16
Order Total: $196.46
Regards
Ron
Albuquerque, NM
Re: Any comments on this Class III Hitch [Re: rrolsbe] #844072 11/05/07 11:42 PM
Seattlegti Offline
Under 2 bills delivered for a class III is great.
If you don't mind post up some before and after pics. I'd like to see how the Tacoma recievers mount up.
Re: Any comments on this Class III Hitch [Re: Seattlegti] #844073 11/20/07 02:02 PM
rrolsbe Offline OP
Found the same hitch delivered for $43 dollars less at etrailer.com. Realtruck issued a price match certificate for $48 for my next purchase, now to find something to purchase. Bottom line could have purchased the Curt hitch and 4" drop for $151 delivered from etrailer.com. The hitch installed easy and uses the same bolts as the bumper brackets, plus two additional bolts included which also bolt to the frame. Bolts directly to the frame, I think the frame would bend before the hitch. The hitch sets back even with the inside back edge of the bumper and below it about a half an inch. The receiver attach point on the hitch extends to about an half inch behind the rear edge of the bumper. Tucks up nicely!
If I get a chance I will post some after pictures.
Regards
Ron
Albuquerque, NM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6097 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-06-17 14:31:39 UTC
