Re: Tires, rub, and how much of a lift? Help quick [Re: JTW] #844235 10/30/07 08:37 PM
Jim_Paget Offline
One quick thing - make sure that you disconnect the hoses from the heater core before you start. It is pretty easy to break a nipple off the heater core if you don't and replacing the heater core is not something that you want to do.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Tires, rub, and how much of a lift? Help quick [Re: Jim_Paget] #844236 10/30/07 11:14 PM
barak Offline
I did a suspension lift and a body lift and I am only running 33". If you are going up to 35" you will definately have to do some trimming with just the body lift , and it will still be a tight squeeze.
Sounds like you got a deal on the BFG though as when I was looking for tires , the BFG 33" were almost 400 a tire , plus the rims on top of that.I ended up going with savero M/T , same tread design , and it cost me 1200 with taxes for 4 new tires and rims , mounted and balanced , plus an extra rim and tire for spare.
Re: Tires, rub, and how much of a lift? Help quick [Re: barak] #844237 11/02/07 06:02 AM
JTW Offline OP
I was just thinking about the clutch linkage, do you have to adjust it at all after a body lift?
Re: Tires, rub, and how much of a lift? Help quick [Re: JTW] #844238 11/02/07 12:37 PM
Jim_Paget Offline
Your clutch is hydraulic. You might have to re-position a line, but that would be all.
Jim Paget
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6073 MB (Peak: 0.6638 MB) Data Comp: Off Server Time: 2026-06-07 04:45:02 UTC
