Steering box play #844505 10/31/07 02:19 PM
88D50 Offline OP
I have an 88 Ram 50, case you couldn't tell by my username and dozens of other posts. <img src="/forums/images/graemlins/lol.gif" alt="" />
Is the steering box play adjustable on these? I seem to have a wandering problem and alot of play in the wheel.
Re: Steering box play [Re: 88D50] #844506 10/31/07 03:39 PM
powerRam50 Offline
yes they are adjustable but have you looked at your idler arm and other steering first?
Re: Steering box play [Re: powerRam50] #844507 11/02/07 12:44 AM
88D50 Offline OP
All new tie rods, and the shop said my idler and pitman arm are in good shape.
Re: Steering box play [Re: 88D50] #844508 11/02/07 12:48 AM
torquemonster Offline
they just have a lot of play...I have never seen a ram 50 that didn't have quite a bit...my old truck had a slight pull to the right so that made it easy to drive...no wandering at all hahah.
Re: Steering box play [Re: 88D50] #844509 11/02/07 03:41 AM
powerRam50 Offline
when you adjust the freeplay make sure you go a little at a time and do several test drives.you dont want to tighten it up to much
Re: Steering box play [Re: torquemonster] #844510 11/02/07 09:26 PM
88D50 Offline OP
I know what you mean. I had a pull untill I had it aligned. Now it wanders. *sigh*
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6059 MB (Peak: 0.6748 MB) Data Comp: Off Server Time: 2026-06-24 14:28:07 UTC
