4x4 Raider Queshion!
#844552
11/01/07 02:16 AM
Hello Gang! Its been about three months since Ive purchased the raider and today I decided to see how the 4 wheel drive works. My question is when I shift from 2wd to 4wd high I see the wheel lock light appear, as wheel as the 4wd double axle light. I here it working well, and the feel of the steering feels more stronger. Though when I shift from 4wd high to 2wd I see the 4wd double axle light disappear, but the wheel lock light still appears, even while driving. When I got home I shut off the truck an return the key to see that the wheel lock light is still on. Is this normal, and how can I turn off the wheel locks? I do have the stock auto hubs.
BTW: what is the correct way to change from 4wd high to low?
Thanks,
1989 Dodge Raider V6 5speed Red/Gray 1978 Mercedes 300D Diesel 1978 Mercedes 240D Diesel
Re: 4x4 Raider Queshion!
[Re: Dieselburns]
#844553
11/01/07 02:55 AM
when you shift to 2wd you have to back up for a few feet.
[Re: powerRam50]
#844554
11/01/07 02:57 AM
when you shift to 2wd you have to back up for a few feet. To disengage the wheel locks...Right?
[Re: Dieselburns]
#844555
11/01/07 03:18 AM
when you shift to 2wd you have to back up for a few feet. To disengage the wheel locks...Right? Yes.
[Re: sparkem]
#844556
11/01/07 03:57 AM
Easiest thing to do is read the drivers door panel. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#844557
11/01/07 04:08 AM
Oh stupid me I totally forgot that. Thanks! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 4x4 Raider Question!
[Re: Dieselburns]
#844558
11/01/07 04:37 AM
to shift from 4high to 4low and visa versa you have to come to a complete stop and put the tranny in neutral.
When you first put it in 4high you must be completely stopped but after that as long as the "wheel lock" light is on you can shift between 2wd and 4high while driving at any speed, just move the shifter.
1989 Montero 4dr V6 3.0l
[Re: Dieselburns]
#844559
11/01/07 04:48 AM
BTW: what is the correct way to change from 4wd high to low? Come to a complete stop before shifting from HI to LO and vice versa.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: 89montero]
#844560
11/01/07 04:49 AM
as long as the "wheel lock" light is on you can shift between 2wd and 4high while driving at any speed, just move the shifter. Not true. My sensor went bad in my Raider in the winter. I went from 4wdhi to 2wd and was going down the road, hit a snowy patch. Engaged 4wd and one of the hubs wasnt engaged anymore. GRRRRRRRSSSSSSHHHHH.... That hub never did lock right after that. <img src="/forums/images/graemlins/frown.gif" alt="" />
