Possible to make torsion bars quiet? Can't sneak in woods! #844665 11/01/07 01:50 PM
TresMon Offline OP
Hey fellas,
Deer hunting season is in full swing here in TN. With my GEN 1 there is no way for me to sneak into the woods. My Torsion bars creak so loud I might as well be playing rap music over a pa system as far as the deer are concerned.
Is there anything I can do?
Thanks!
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: TresMon] #844666 11/01/07 02:28 PM
It may not be the bars, per se, but rather the lower front mounting points, a.k.a. the lower a-arm pivot points. Mine would squeal like crazy. There are no grease fittings there, so I just douse both ends of the a-arm with WD-40 and they're quiet for a week or so. Hope that helps.
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: JohnnyBfromPeoria] #844667 11/01/07 04:56 PM
TresMon Offline OP
I'll soak it with the WD and see what happens.
Thanks.
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: TresMon] #844668 11/01/07 09:01 PM
ForcedAir_Montero Offline
I'd get out walk...
but that's just me, I don't roadhunt. <img src="/forums/images/graemlins/notooth.gif" alt="" />
As for the bars, if you can white lithium grease in there, it will last longer than others.
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: ForcedAir_Montero] #844669 11/01/07 09:52 PM
I tried spray lithium grease, but it wouldn't get in to where it made a difference. Sometimes I'd WD-40 it first, then add a layer of the grease to help hold it in there, too. As I recall, that did about the same thing as just the WD-40 by itself.
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: JohnnyBfromPeoria] #844670 11/02/07 11:15 PM
G
generation_one Offline
yep them deers ull come a runnin to that wd40... spray some on yer shoes too
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: generation_one] #844671 11/08/07 01:38 PM
Baldylocks Offline
How about WD on yer boots and doe pee on the bars <img src="/forums/images/graemlins/smile.gif" alt="" />
1990 MonTERROR
183.07 cubic inches of worn out FURY
New ALTINATOR
And uh... new radiator hoses UPPER AND LOWER,
SAGGING COILS, dead SHOCKS
Worn 29 x something x something else STREET TIRES
GET SOME
Re: Possible to make torsion bars quiet? Can't sneak in woods! [Re: TresMon] #844672 11/08/07 10:50 PM
BobShaw Offline
Mine has bearing grease packed into both splines front and rear. Never squeaks.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6232 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-06-09 04:57:24 UTC
