rod bearing clearance specs on a 22re #845186 11/03/07 10:37 PM
trashcanman Offline OP
im plastgaging my rod bearings right now. what are the specs they should be at?
Re: rod bearing clearance specs on a 22re [Re: trashcanman] #845187 11/03/07 11:41 PM
Toybluggie Offline
If you dont have it already, check the sticky and download a FSM. Will help you out alot.
Rod bearing
Max = 0.10 mm
Standard = 0.025 - 0.055 mm
84 22re pickup
Re: rod bearing clearance specs on a 22re [Re: trashcanman] #845188 11/04/07 04:01 PM
OOP'S Offline
I would not even think about rebuilding an engine with out an FSM sitting on the work bench.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: rod bearing clearance specs on a 22re [Re: trashcanman] #845189 11/04/07 04:55 PM
engnbldr Offline
>>>*I use the oil wedge at the side of the rod myself, that takes feel of course and a few years of doing it. I haven't used plastigage in ages but it works fine.
In domestic sizes, I use a minimum of .0008" and these will run fine at .0025". Past that I start measuring the rod big end and the main line, plus the shaft crankpin looking for why. The actual bearing crush (friction) is all that keeps the bearing shell in place, if the bearing spins the engine dies.
What we never want to see is a large difference, if reasonably consistant, bolt her up....*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6016 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-24 12:57:02 UTC
