Wiperblade problem.... #845382 11/04/07 10:45 PM
N
Nick_ Offline OP
So, i got in my shocks/wiper blade motor yesterday night, and put in the wiper blade motor today. But...do to my luck, when i tried it after i hooked it all up..nothing happened. No noise from it, it appears to have not started. <img src="/forums/images/graemlins/confused.gif" alt="" />
Now, i'm looking to see what's the problem, could it be the actuator arm? Should I be able to manually move the actuator arm by bulling it to move the windshield wipers?
Could I just be overlooking something, the fuse seems good..but i don't know, the wiring seems okay also...any insight would be appreciated, can't really go anywhere if I can't see past the rain!
<img src="/forums/images/graemlins/notooth.gif" alt="" />
87 Dodge Raider 2.6l KYB Shocks, 35 BFG Mud Terrains!
3 Inch Body Lift
Custom front and rear bumpers
Roof Rack
Coming soon!
Re: Wiperblade problem.... [Re: Nick_] #845383 11/05/07 03:38 AM
Have you pushed the wiring connector for the motor all the way in?
Re: Wiperblade problem.... [Re: Nick_] #845384 11/05/07 04:54 AM
LRJ4x4 Offline
try to hot wire it, just to test that it works. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wiperblade problem.... [Re: LRJ4x4] #845385 11/05/07 04:01 PM
Binksomatic Offline
If you haven't already, check to make sure that the pivot for the passenger-side blade is tightly secured to the cowl. If there is flex on that pivot it will lock up the system.
89 Montero 3L. Stock.
Rust and Repairs at Equilibrium
Re: Wiperblade problem.... [Re: Binksomatic] #845386 11/05/07 04:03 PM
N
Nick_ Offline OP
I got it to work, it was the fuse, thus I needed NO MOTOR, thankfully I can return it. (Yay for my dad overlooking it)
The motor works..but the wiper blades don't, i'll make sure to check the pivot and all that, see if that gets them to work. <img src="/forums/images/graemlins/smile.gif" alt="" />
3 Inch Body Lift
Roof Rack
Coming soon!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-21 09:48:44 UTC
