dumb nuby Q (rough 3.0 idle) #845531 11/05/07 05:53 PM
daan Offline OP
YES I READ THE FAQ first!
Time to add my dumb question. I have a 91, 3.0/auto, 155K truck. It idles roughly, and all the lights flicker(Dash, headlights,dome lights etc). The PO replaced the "Throttle Position Sensor" and all the tuneup stuff (I have reciepts anyway...) All the belts and hoses were done, too...it still idles funny. What's next? I THINK the low idle and the flickering is related since the lights are fine once I'm actually driving. Thank you all for the good forum.
Re: dumb nuby Q (rough 3.0 idle) [Re: daan] #845532 11/05/07 06:24 PM
8
89IsMine Offline
I would check the IAC (also known as the ISC or Idle Speed Controller) first. There's a recent thread about this, and the Factory Service Manual gives the procedure to check the coils with a VOM. The flickering lights are most likely due to the alternator not putting out a steady voltage due to your low idle rpms.
That's where I'd start. I'm sure others with much more knowledge than me will chime in. Let us know how you get on! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: dumb nuby Q (rough 3.0 idle) [Re: 89IsMine] #845533 11/06/07 12:01 AM
G
generation_one Offline
could very well be that or bad connections...look at the alrernator, I mean charging circuit, soon for sure
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.5949 MB (Peak: 0.6490 MB) Data Comp: Off Server Time: 2026-11-15 06:00:29 UTC
