Parked, now no spark. 1990 Montero 3.0L. Need some troubleshooting help
#845930
11/08/07 01:00 AM
Hi,
I parked my 1990 3.0L V6 4-door 4WD Montero about 6 months ago. I charged up the battery and tried to start it. It cranks hard but won't turn over. I tested for spark and has none. Plug wires aren't new but newer. I swapped out for a new distributor cap & rotor, even though I didn't figure that was the problem they were cheap. I had the Ignition Control Unit tested at a local auto parts store. Tested fine. Swapped in a new ignition coil. Still no spark.
I'm looking for suggestions on what to try next. I have the Haynes manual and it isn't very helpful. Could the photo optic sensor be the problem? It ran just fine when I parked it.
Thanks much!
Re: Parked, now no spark. 1990 Montero 3.0L. Need some troubleshooting help
[Re: thermarest]
#845931
11/08/07 02:37 AM
Corrosion on ecu wiring?
Swolen ECU caps?
[Re: thermarest]
#845932
11/08/07 01:00 PM
Hi,
Thanks much! Same happened to me I parked the truck for about six months it never started again did pretty much all the above and nothing.I put a spare ecu in and started right up
2003 Montero Limited White 2001 Montero GLS Diesel 1990 Montero Black Off Road Package. 1990 Montero Parts Truck.
[Re: koolaid6666]
#845933
11/08/07 05:16 PM
Thanks for the ECU suggestion. I will investigate that route. I've looked in the Haynes book and via google for about 15 minutes. Can't find a solid reference to where the ECU is. Where is it??
Also, is there any chance that the actual distributor is bad? That was the only other think I could think of. Thanks.
[Re: thermarest]
#845934
11/08/07 06:11 PM
The ecu is under the glove box on the passenger side, 3 - 8MM bolts and then it drops down to the floor. Look for black stains or ooze under the capacitors.
mgpman 88 Trooper LS
[Re: thermarest]
#845935
11/08/07 06:11 PM
on my '91 it is right under the glove box and above passenger floor below the heater blower, it has a cover over it.
'91 montero a/t cranked t-bars 31x10.5x15 212k '90 toyota extra cab 320k v6 5 speed 31's 4x4 '99 expedition 17" alloys v-8 207k 4x4 '88 BMW 325iX 247k AWD '59 Willys Jeep Koenig PTO winch and hardtop 28k
