2WD tranny how to make it 4WD???? #846198 11/09/07 07:11 AM
cokeslingin Offline OP
I have what looks to be a 2WD W56 and possibly a 2WD L45. Went to MarlinCrawlers and looked up the info on the transmissions. Even the blind guy next to me noticed the differences between the 2WD and the 4WD transmissions. Do I need to find a 4WD W tranny and swap the necessary parts or is there a whole lot more involved in the process? Any and all help will be greatly appreciated. Thanks!!
Re: 2WD tranny how to make it 4WD???? [Re: cokeslingin] #846199 11/09/07 07:59 AM
kewlynx Offline
Unless someone knows different, I don't think you can put a transfer case onto the tail end of a 2wd tranny. Great question!
**ubi apis- ibi salus**
Re: 2WD tranny how to make it 4WD???? [Re: kewlynx] #846200 11/09/07 08:21 AM
From what i've can tell, the difference seems to be where the shifter housing (??) bolts on. Again I'm pulling this info from MC, going off the pics on the transmission thread. Theoretically if I can get my hands on the section of the tranny that the tcase bolts too, that section should bolt to my tranny, right?? Now if thats the case, will any top shift tcase bolt up or will I be sending MC some of my $$ to correct this issue?
Re: 2WD tranny how to make it 4WD???? [Re: cokeslingin] #846201 11/09/07 08:25 AM
More specifically will my tcase from my L tranny bolt up to the W tranny??
Re: 2WD tranny how to make it 4WD???? [Re: cokeslingin] #846202 11/09/07 05:28 PM
fourwd1 Offline
The top shift case from an L series 4WD trans will bolt-up to a W56 series 4WD trans that uses a top shift case (W56-A&B IIRC). The later W56-C&D trans use a forward shift case.
However, you would have to replace the shift rods in the case from the L series trans with the shorter shift rods from a case that mates with a W56 series trans.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 2WD tranny how to make it 4WD???? [Re: cokeslingin] #846203 11/09/07 05:28 PM
4Crawler Offline
I once heard that you can swap the back section between 2WD and 4WD trannys (of the same model), but not sure about that. You could probably ask about that on MarlinCrawler's web forum and find out for sure.
Yes, you can bolt up a top-shift gear drive t-case to a W56 (4WD) tranny.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6106 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-06-17 20:44:39 UTC
