My replacement engine just blew up... I think #846560 11/11/07 06:18 AM
Superzuk Offline OP
Hey everyone. I installed the replacement motor with 96000 kms on it into the Kia about a month and a half ago. Well, driving to work friday morning it looked like it was getting hot on the guage. (started going above half...) I was about 500 Meters from work, so I continued there... Well, now the thing needs to crank over forever before it'll start, and it seems gutless when it's running.
It's a 2000 Sportage 4x4, with the DOHC 2.0 litre motor... I was so happy with this thing, but now I'm totally disappointed..
Any idea what I could check? Any ideas what would cause it to overheat like that? Are these things prone to real problems after a slight overheat? Would it be a warped head, head gasket, or melted rings???
Man.... I am disappointed... <img src="/forums/images/graemlins/frown.gif" alt="" />
Anyways, any help would be appreciated.
Thanks
Re: My replacement engine just blew up... I think [Re: Superzuk] #846561 11/11/07 09:43 AM
bombardj1 Offline
could be the fan clutch or the thermostat. is the rad fld. low ? my Kia runs just a little 1/2 on the gage to over heat it would have to boil over or go all the way up the gage and stay there did you run it low on oil ? when you replaced it did you replace any parts when it was out T-belt water pump etc. ?
Re: My replacement engine just blew up... I think [Re: bombardj1] #846562 11/14/07 01:27 AM
BG98EX Offline
Could be just a plugged up exhaust.
Like a plugged converter...
Run it around close to home one night until it gets hot.
Then run home and have a look underneath at the converter.
I've seen them glow red on other vehicles.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5920 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-12 06:13:06 UTC
