AIR CONDITIONING NOT WORKING #847294 11/16/07 09:33 PM
MRT100 Offline OP
Hello every one,
97 T100 V6 5spd 4WD ext cab
IÆm having problem with my air conditioner.
When it stoped cooling (coolant loss ???) I have attempted to recharge it.
After applying 1 can of 134a it was cooling again.
Unfortunately when driving to work next day I could smell coolant in the cabin.
It looks like the coolant was being pumped into the cabin through the cabinÆs vents.
I believe that problem is with a cooling unit û evaporator to be exact.
Is evaporator exchangeable or it would be entire unit?
Anybody experienced similar problem?
How did you fix it?
Any suggestions appreciated.
Thanks.
Re: AIR CONDITIONING NOT WORKING [Re: MRT100] #847295 11/19/07 09:11 PM
jmoser Offline
On most A/C systems the evaporator is a separate and serviceable / replaceable part. [My 2001 Durango needed one.] Won't be a cheap part though, not sure if they can be re-brazed, etc. for repair.
Many Japanese imports had the A/C system added in the US at the port of entry to minimize duty costs - not sure about T100s but this may mean that it was designed to be a bit easier to get to and service.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: AIR CONDITIONING NOT WORKING [Re: jmoser] #847296 11/20/07 01:33 AM
E
eleet Offline
You can reach under the dash on the pax side and put your hand on the evaporator enclosure. Probably you can just remove the glovebox to get clearance for it.
97 T100 4x4
97 328i
95 540i restoration project
Re: AIR CONDITIONING NOT WORKING [Re: eleet] #847297 11/20/07 08:07 PM
MRT100 Offline OP
Thanks for your input guys.
So, assuming my evaporator is bad (cracked or rusted).
I must replace it or do I have a chance fixing it?
- welding, gluing, etc?
What would you suggest for a replacement?
- Toyota new $180.00
- aftermarket about 80.00
Thanks
Re: AIR CONDITIONING NOT WORKING [Re: MRT100] #847298 11/20/07 09:55 PM
garym Offline
H20 man was selling the whole A/C kit. You might see if he still has it and how much he wants for it.
A/C etc.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: AIR CONDITIONING NOT WORKING [Re: garym] #847299 11/20/07 10:16 PM
ErikB Offline
Toyota Moderator
Find the leak before you go buying any parts. It could be as simple as a bad o-ring at one of the connections.
http://home.4x4wire.com/erik
Re: AIR CONDITIONING NOT WORKING [Re: MRT100] #847300 11/21/07 12:47 AM
E
eleet Offline
Everything comes apart. Get an O ring kit like Erik advises smile
97 T100 4x4
97 328i
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6141 MB (Peak: 0.6880 MB) Data Comp: Off Server Time: 2026-06-25 05:39:59 UTC
