Page 2 of 6 1 2 3 4 5 6
Re: 2001 Cherokee? [Re: Cen_Tex_KIA] #847359 11/18/07 07:51 PM
Bigbird79 Offline
The NP 231 will have 2HI, 4HI, N, 4LO. This will allow you to only use 4WD when you Need it, instead of spinning all the drivetrain all the time. With All Wheel Drive, the transfer case has to have a differential in it too, to allow for the different movement between the front and rear end when turning. ItÆs just one more thing to go wrong.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: 2001 Cherokee? [Re: Cen_Tex_KIA] #847360 11/18/07 08:01 PM
the_other_guy Offline
This one has part time 4w, 4w high and 4w low.
I wouldn't be interested if it didn't have a low end xfer case.
Is this the best one you were talking about?
Just wondering, is that supposed to say "2w, 4w high and 4w low." Or are they all supposed to be 4s?
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: 2001 Cherokee? [Re: the_other_guy] #847361 11/18/07 10:05 PM
Cen_Tex_KIA Offline OP
Nope, its 2w, n, part time 4w, 4w h and 4w l.
Thats why I'm curious?
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: 2001 Cherokee? [Re: Cen_Tex_KIA] #847362 11/19/07 09:56 AM
the t-case shifter has 5 selections? I dont know about that then, that seems strange, but I'm fairly new to the hobby, so there is a lot i have not seen. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: 2001 Cherokee? [Re: the_other_guy] #847363 11/19/07 04:04 PM
Brown81CJ5 Offline
There's not really 5 is there? <img src="/forums/images/graemlins/confused.gif" alt="" />
There should only be 4L, N, 2H, 4H. Being able to shift it into 2WD makes it a part time transfer case...meaning that it does not have full time 4WD, so there should not be a "part time 4WD setting" on the t-case shifter. I'm betting there is actually only 4 settings.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 2001 Cherokee? [Re: the_other_guy] #847364 11/19/07 04:44 PM
Bigbird79 Offline
It sounds to me like this jeep has the NP242 "Selec Trac" Transfer case in it, which has a shift pattern of 2WD, 4WD Part Time, 4WD Fulltime (AKA All Wheel Drive), N, 4WD Low. It has the center differential in it. To me itÆs just one more thing to go wrong. Personally I looked long and hard to find my Jeep up here with the 4.0L, AX15 5 speed and the NP231, but then I think I saw ~50 Automatic XJ's for each Manual transmission XJ.
Sean
Re: 2001 Cherokee? [Re: Brown81CJ5] #847365 11/19/07 04:54 PM
F
Fred Blackstone Offline
Some Cherokees, Libertys and Grands have the NP242 transfer case which has part time and full time 4WD combined in one transfer case (just to muddy the waters <img src="/forums/images/graemlins/lol.gif" alt="" />). I can't recall the gear order exactly: but, the NP242 includes 2 wheel drive, full time 4 wheel drive, a real neutral, and part time 4 wheel drive high, and part time 4 wheel drive low modes of operation. full time 4 wheel drive is basically all-wheel drive, allowing the vehicle to be in 4 wheel drive on dry pavement without causing harm to the transfer case.
Re: 2001 Cherokee? [Re: Fred Blackstone] #847366 11/19/07 10:05 PM
Brown81CJ5 Offline
Thanks for the insight guys. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Gun it and run it!
Re: 2001 Cherokee? [Re: Brown81CJ5] #847367 11/20/07 02:24 AM
Its the select trac...........did I buy a bummer, or is the t case as good as the one without?
(And it has the little Dana, not the 8 3/4 Chrysler.) <img src="/forums/images/graemlins/scared.gif" alt="" />
2w........4w pt.......N........4w h........4w l
Re: 2001 Cherokee? [Re: Cen_Tex_KIA] #847368 11/20/07 02:27 AM
It pulls straight in 2w, has posi.........and it pulls straight in all 4w positions. <img src="/forums/images/graemlins/shiner.gif" alt="" />
PHP: 7.4.33 Page Time: 0.825s Queries: 15 (0.004s) Memory: 0.6419 MB (Peak: 0.7492 MB) Data Comp: Off Server Time: 2026-06-10 04:23:15 UTC
