22r Carb settings #847579 11/18/07 09:07 PM
daveowen Offline OP
Hey guys
I just put a rebuilt 22r into my 1980 4x4 - Crank bearings, piston rings, all gaskets, valve seals, etc.
Now, I think my problem lies within the carb settings. It idles at around 1100 rpm, and if i bring down the idle mixture screw it runs terribly (sputters, etc) below 1000rpm. What are the stock settings for all of the mixture screws on the carb?
Thanks in advance,
Dave
Re: 22r Carb settings [Re: daveowen] #847580 11/18/07 09:23 PM
Scerb Offline
Carb FAQ
Re: 22r Carb settings [Re: Scerb] #847581 11/18/07 09:39 PM
L
Locked_Solid_Toy Offline
Yeah i had problems with my carb when i got my new rebuit. Honestly man, i realize it isn't probably in the budget right now since the reuild but you should just look into gettin a Webber Carb, they work a lot better and are less of a headache, and they give you more power anyway.
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: 22r Carb settings [Re: Locked_Solid_Toy] #847582 11/18/07 09:45 PM
Scerb Offline
I.. disagree. Webers are much more picky and touchy with adjustments. They perform better on-road (once tuned properly), but the stock aisin is a little better offroad with angles.
Re: 22r Carb settings [Re: Scerb] #847583 11/19/07 03:56 AM
daveowen Offline OP
I read the FAQ, but i still dont seem to see where all of the screws are identified / mentioned in terms of how many turns out from seated.
Re: 22r Carb settings [Re: daveowen] #847584 11/19/07 04:14 AM
Scerb Offline
http://www.bluebassdesign.com/boonin/carb_faq/#is
Its all in that section. I don't have a diagram up on the location of the screws, and sorry for that, I jsut never got around to it.
This exploded diagram shows the screws locations, however:
http://www.bluebassdesign.com/boonin/carb_faq/images/22r_carburetor_diagram.jpg
To reset the idle mixture screw for a 22R:
ò 1982 - 2.5 turns from fully closed
ò 1983-88 - 4 turns from fully closed.
Re: 22r Carb settings [Re: Scerb] #847585 11/19/07 04:40 AM
daveowen Offline OP
The 22r in my 1980 was swapped in, - how do i nkow if its an 1982 0r 83-88?
Re: 22r Carb settings [Re: daveowen] #847586 11/19/07 04:49 AM
kewlynx Offline
Try each setting and see which one works.
**ubi apis- ibi salus**
Re: 22r Carb settings [Re: daveowen] #847587 11/19/07 06:12 AM
Scerb Offline
If you look in that diagram linked above, on the left side: see the piece (its not labeled) that is in between the text AAP and Choke Opener? That cap (that is not labeled) I'm fairly sure it was only on pre-83's. If you don't have that cap, there will just be an empty uncapped section in the carb body, and its most likely an 83+.
Remember, once you get the base-line setting, you will still need to tweak it per the procedure I mention in the faq section linked above <img src="/forums/images/graemlins/kewl.gif" alt="" />
Good luck,
Scerb
Re: 22r Carb settings [Re: Scerb] #847588 11/19/07 05:07 PM
G
Greg_Canada Offline
He's got a dual-row timing chain so it must be 81-82.
89 4Runner
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6362 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-07-16 08:43:54 UTC
