Page 1 of 3 1 2 3
p/s pump and box #848175 11/21/07 06:50 PM
8
89Diesel Offline OP
I swapped my 2.6 for a 2.3 diesel in my 89 D50. The diesel came out of a 86 Ranger and had the p/s pump attached running a serpentine belt. I left the this setup on (can't get V pulleys for the engine) and made up some fittings to connect to the stock box. Worked for a few days.
The pump was making a slight buzzing sound, and then it blew the steering shaft input seal on the box. (Ranger puts out 1500 psi. Too much for Dodge box?) Does anyone know where I can get a new seal? Or possibly a new box? I can't get either locally.
I guess I also have to change the pump back to the stock Dodge, which looks like I have to fire up the lathe to swap pulleys (gas has V, need serp. and the pulleys dont interchange) or is there a pump off of some type of other vehicle w/serp pulley that will work?
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: p/s pump and box [Re: 89Diesel] #848176 11/21/07 07:10 PM
dylanb Offline
Pretty interested to hear the verdict on this one.. I am also planning to use the Ranger pump and Mitsu box on my swap. I wouldn't think that the pressures are so different between the two systems that it would cause a seal to burst.....
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: p/s pump and box [Re: 89Diesel] #848177 11/21/07 11:29 PM
Y
yankneck696 Offline
Most mitsubishi's & Chryslers have the same pump. Just go to the bone yard & find one that mates to the belts...
\Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: p/s pump and box [Re: yankneck696] #848178 11/22/07 03:00 AM
Powell already solved this one on the diesel board. He's swapping a 2.3 from a Ranger to an 87 swb monty and had a pulley cadcammed. Just read the post the other day.
Re: p/s pump and box [Re: fasteddy] #848179 11/22/07 03:05 AM
LandRaider Offline
The Mitsu Box gets really mad when you put a 4.3 Pump on it as well. At least it did in my case.
Re: p/s pump and box [Re: LandRaider] #848180 11/22/07 11:20 AM
Chris_J Offline
Has anyone thought about using an AGR pump and box?
Re: p/s pump and box [Re: 89Diesel] #848181 11/22/07 12:04 PM
If you look at the Mitsus made in the 90s most all of them have serpentine belts. I would grab one from a V6 pickup or Montero as my first choice. Try to get one from a truck so it matches the flow specs of the steering box.
Mitsubishi uses PS pumps that have a liner flow output, the American pumps are variable flow, more rpm more fluid. As others have found, they do not work.
Re: p/s pump and box [Re: 89Diesel] #848182 11/23/07 05:01 AM
dylanb Offline
1500 psi sounds REALLY high to me....
I don't know too much about PS systems, but from what i can tell by looking at the pump there is a spring that controls the output pressure and/or volume. Would changing the spring rate on this be an effective way to lower the output pressure? Just trying to see if I can work with what I have because I don't want to have ANOTHER pulley fabbed up don't really want to wait on a v6 pump that may not be what I need either. Thanks guys
-Dylan
Re: p/s pump and box [Re: dylanb] #848183 11/23/07 05:06 AM
LandRaider Offline
1500 psi sounds REALLY high to me....I don't know too much about PS systems
1000-1500 psi is not uncommon.
Re: p/s pump and box [Re: OldColt] #848184 11/23/07 05:08 AM
NathanC Offline
How is it regulated then? I thought it was a simple vane pump.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6425 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-06-06 12:56:44 UTC
