83 CJ7 info #8483 03/21/03 02:16 AM
mwhite Offline OP
I just bought a 83 CJ7 with a 258, auto, dana 300,
AMC 20 rear, 30 front. My question is the trans.
a tf999 or other, also thanks to all who answered
my questions from my other posts. my jeep also has
a hardtop, 31" buckshots ,warn 8274, and air conditioning
one piece rear axles.
any body know what my gear ratio is.
the jeep has no rust and is in very good shape
<small>[ March 20, 2003, 08:25 PM: Message edited by: mwhite ]</small>
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: 83 CJ7 info #8484 03/21/03 03:13 AM
There should be a tag on your differential covers, but sometimes they don't last. I would look there first. Counting the teeth on the r&p is really the best, most foolproof way, but I know there are others out there.
Good Luck
Chip
<small>[ March 20, 2003, 09:14 PM: Message edited by: arcteryx1969 ]</small>
Re: 83 CJ7 info #8485 03/21/03 10:48 PM
There is a code on stamped on the axle housing. The code is on the offroad.com website. http://www.off-road.com/jeep/tech/axle/amc20.html
You can llok up your stamp to see what the gear ratio is. Probably have to copy and paste the link.
Re: 83 CJ7 info #8486 03/22/03 04:54 AM
I recently asked the same question and got the same responses. ( thanks to all responses) however the tags are long gone and i spent 25 min underneath my CJ looking for these codes. Never found them. Guess Ill start counting teeth
Dave k
85 CJ7 ...hei, 2BBL MOTORCRAFT, 31" TIRES, 1" LIFT, GOT RID OF THAT CRAPPY COMPUTER...WORK IN PROGRESS
<small>[ March 21, 2003, 10:55 PM: Message edited by: sampson9dk ]</small>
Re: 83 CJ7 info #8487 03/24/03 03:48 PM
sampson9dk:
You'll find the codes on the actual gear set. Sorry nobody told ya! Remove the cover and they should be right on the gears. You might have to spin the gears to see.
If you've got an AMC20 rear, I never could find the right gasket for it. Mopar makes a "specific" diff cover pucky (silicone) and that works great. Just in case you can't find a gasket.
Good luck to the both of ya!
Re: 83 CJ7 info #8488 03/28/03 04:07 AM
if you are looking for ratios and other tech specs go check out the link "Q" posted. lots of good info at that site. check it out!
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.5973 MB (Peak: 0.6659 MB) Data Comp: Off Server Time: 2026-11-16 01:28:02 UTC
