gears #848610 11/24/07 08:13 PM
kingfoss Offline OP
i was wondering if i can run 3.0 gears in the rear and 3.5 gears in the front untill i can afford to regear both axles.
thanks
2000 TJ 5" lift
33" BFG AT
Rear 4-link coming soon
Front hp dana 44 and frod 9" Rear coming sonn
Re: gears [Re: kingfoss] #848611 11/24/07 08:50 PM
BigJim Offline
YES you can! But you should disconnect the 4X4 because you will ONLY be able to use 2 wheel drive until both gears are the same..
Also the difference betwee 3 and 3.5 is prolly not enough to change.. You might want to rethink which gears you really want in there.
Re: gears [Re: BigJim] #848612 11/24/07 09:17 PM
kingfoss Offline OP
i am going to 4.88 in it when i get the money i need to pu tthe rear axle in so the jeep can be driven again can i run 3.0 and 3.07 in 4 wheel drive?
2000 TJ 5" lift
33" BFG AT
Re: gears [Re: kingfoss] #848613 11/24/07 10:04 PM
BigJim Offline
Foss I betcha the 3 and 3:07 are the same gears and someone just left off the :07 from the 3... I don;t think it is possible to gear a straight 3:00
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5985 MB (Peak: 0.6539 MB) Data Comp: Off Server Time: 2026-10-24 10:56:31 UTC
