I think Im missing parts #848720 11/25/07 10:23 PM
kneedragger Offline OP
So as of recent I have been hearing this rattling sound comming from the front right Hub. I remove the tire and the hub cover and behold I missing parts, I am missing the compression spring and the ring it sits on. I have done service on 4x4 truck before but never noticed and springs would swapping to a Man locking hub eliminate all that crap inside the hub? What else needs to be done to do an auto 2 man hub swap?
1986 Isuzu Trooper 2.3
2004 Suzuki GS500F
Re: I think Im missing parts [Re: kneedragger] #848721 11/26/07 05:41 AM
boritz Offline
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: I think Im missing parts [Re: boritz] #848722 11/27/07 12:52 AM
OK so I understand the swap but I couldnt tell what old parts will be removed. Will my truck still use the old compression spring or is that going to be removed?
2004 Suzuki GS500F
Re: I think Im missing parts [Re: kneedragger] #848723 11/27/07 03:48 AM
boritz Offline
There is a diagram of the manual Aisin hub here http://www.yankeetoys.org/Documents/AisinHubs.pdf
I would think that you don't need any of your auto-hub parts - just replace with the manual hub.
Note that on some vehicles (mine included) the bolt illustrated as inserting into the end of the drive shaft was replaced by a circlip sitting in a groove around the end of the shaft.
Re: I think Im missing parts [Re: boritz] #848724 11/27/07 06:19 AM
mlclark Offline
Isuzu Moderator
The diagram above is good and it works well, but it is for Toyota. Isuzu has never used a bolt in the stub shaft. It has always been a c-clip.
Michael
Re: I think Im missing parts [Re: mlclark] #848725 11/27/07 08:56 AM
boritz Offline
Thanks for the lesson Michael <img src="/forums/images/graemlins/cheers.gif" alt="" /> - I didn't know that - I've only owned my current Isuzu <img src="/forums/images/graemlins/baby.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6105 MB (Peak: 0.6808 MB) Data Comp: Off Server Time: 2026-06-07 03:34:54 UTC
