Re: 3.2 6vd1 valve adjustemnts [Re: boritz] #849217 11/30/07 04:44 AM
JLEMOND Offline
YES ALL V6,S FROM 98 AND LATER ARE ALL DOHC. BLOCK IS THE SAME DESIGN AS THE OLDER ENGS , AND A LOT OF THE PARTS ARE INTERCHANGABLE ON THE 3.2 ENGS BUT NOT THE 3.5 , THE BLOCKS ARE NOT INTERCHANGABLE WITH THE OLDER ENGS AS FAR AS INTERNAL ENG PARTS AS THE DECK SURFACE IS DIFF WITH THE OIL AND COOLANT HOLES , AND THE HEADS ARE NOT SWAPPABLE, ALLTHOUGH THEY LOOK VERY CLOSE , THEY ARE MUCH THINNER IN DESIGN THAN THE OLDER ENGS , BUT THEY ARE THE SAME BASIC DESIGN. THE 3.2,S ARE THE SAME BORE AND STROKE AS THE OLDER ENG AND THE CRANKS ARE INTERCHANGABLE , BUT NOT THE RODS OR PISTONS , BLOCK HEIGHT HEIGHT IS DIFF, PISTONS ARE SHORTER MUCH LIKE THE 3,5,S JERRY
Re: 3.2 6vd1 valve adjustemnts [Re: deermagnet] #849218 11/30/07 12:07 PM
9
99_Fronty Offline
This is an Isuzu tech video for valve adjustment on the 3.2L and 3.5L. It's not the greatest quality, but good enough.
Wow, where did you get these videos? That must be Jerry with the white beard in one of them. Didn't know he was an Aussie, Ha!
Andrew.
Re: 3.2 6vd1 valve adjustemnts [Re: JLEMOND] #849219 11/30/07 10:53 PM
boritz Offline
YES ALL V6,S FROM 98 AND LATER ARE ALL DOHC...
Thanks Jerry <img src="/forums/images/graemlins/cheers.gif" alt="" />
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5998 MB (Peak: 0.6531 MB) Data Comp: Off Server Time: 2026-10-21 17:13:59 UTC
