Ford shock tower mounting question #849364 11/29/07 04:37 AM
9
95mini Offline OP
Should I weld them on or bolt them on?
I was thinking about bolting them using the stock holes in the tower through the frame. Then also making a gusset that would be welded to the tower and bolt into the empty IFS threaded holes where the control arm/torsion bar used to be(beside the motor mount).
Re: Ford shock tower mounting question [Re: 95mini] #849365 11/29/07 06:47 AM
Scerb Offline
Why wouldn't you weld them? Its stronger and easier..
Re: Ford shock tower mounting question [Re: Scerb] #849366 11/29/07 01:14 PM
9
95mini Offline OP
I just figured it would be easier to remove if I ever wanted to change my setup.
Re: Ford shock tower mounting question [Re: 95mini] #849367 11/29/07 03:49 PM
RatLabGuy Offline
You have to weld up that guesset anyway... I'd just weld them on. For the time saving and added strength, if yo uwanted to remove them later, it'll just be a cutoff wheel and grinder.
I'm never a fan or drilling holes in the frame. JMO.
Question Reality.
Re: Ford shock tower mounting question [Re: RatLabGuy] #849368 11/29/07 11:32 PM
Staceman Offline
X2 !!!!!!!!!!!!!!!!
Especially a Toyota gusseted 4x4 full box frame!!!!
(hardest part of a crossover steering box conversion, drilling thru that damn frame.)
Re: Ford shock tower mounting question [Re: Staceman] #849369 11/30/07 12:01 AM
rondog Offline
Could you please give me the part number of those f250 towers? Done a search but could not find. Thanks Ron
Re: Ford shock tower mounting question [Re: rondog] #849370 11/30/07 12:11 AM
Adam F Offline
E5TZ18183A
I got the part number on my site in my parts list
http://home.4x4wire.com/adamf/88/sas.htm
97 4R, stock, daily driver
Re: Ford shock tower mounting question [Re: Adam F] #849371 11/30/07 07:17 AM
4Crawler Offline
While I don't run the Ford shock towers, my front shock mounts have been bolted on for about 10 years now:
http://www.4crawler.com/4x4/4R_suspension-III.shtml#ShockTowers2.0
A pair of bolts through the frame and brackets clamp the bracket to the frame and then a pair of self-tapping bolts hold the two support towers tight to the frame (used to have a problem with squeaking there before adding those two bolts):
And I have had the brackets on and off maybe a half dozen times over the years, making improvements and modifications for different body lift heights and axle locations. Have to pull them off again here in the next few weeks to take some final measurements.
Re: Ford shock tower mounting question [Re: 4Crawler] #849372 11/30/07 09:11 PM
bkg Offline
Depends on the frame and where you want to mount them.
Personally, I'd bolt them. Had this on my 85 4Runner and it worked great. Welded them on my 86 xcab and they eventually tore off (though they were welded on top of the frame rather than on the outside due to need).
Brian K. Gallus
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6271 MB (Peak: 0.7305 MB) Data Comp: Off Server Time: 2026-10-26 23:43:54 UTC
