problems with ignition switch/key,, need help #849676 11/30/07 06:30 PM
O
Omega Supreme Offline OP
where to start. First its a 94 4runner. Its my gf's and ashe lives in cali. I am going to be towing it back up to washington. It was broken into and i think someone jammed a screwdriver into the ignition making the key useless. I took out the whole steering colum to reomove the key cylinder. Here is the problem, you need the key in to remove it. How do i get this out to put a new one in? The steering wheel is locked and i need to be able to move it to put it on the tow dolly. Would a locksmith be able to help? any help is greatly appreciated. Thank you. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: problems with ignition switch/key,, need help [Re: Omega Supreme] #849677 12/03/07 05:27 AM
kewlynx Offline
I've been down this road, only the guy where I parked my rig at wouldn't give me back my key (long story). Take a paperclip to stick into the little hole on the assembly, press. While doing so, work a small flat tipped screwdriver around and work it out of there. Takes some patience, but can be done. I didn't break anything, LOL!
Where you insert the paperclip is what 'unlocks' the assembly from the column. If it's already had a screwdriver stuffed in the key slot, give that a try first with the paperclip before proceeding with what I suggested.
Took the assembly to a locksmith and got rekeyed once I got my rig out of there.
Good luck!
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5885 MB (Peak: 0.6370 MB) Data Comp: Off Server Time: 2026-06-18 13:38:39 UTC
