Re: Hubs not unlocking
[Re: MadGary]
#849790
12/02/07 12:14 PM
I would love to be able to fix the problem myself, but I live in an apartment complex, and I have no where to work on it. I need it to be fixed ASAP, because It is my Daily driver. The outer cap on the hubs is threaded, you unscrew it by hand and at least spray a light lubricant in there. The cap may be tight as it seats on an Oring that would be dry. This is not much more work than checking oil level and tire pressures which I hope can be done at a condo lot.
[Re: MadGary]
#849791
12/02/07 05:36 PM
Welcome to the age old saga of the automatic hubs. Nothing can go wrong go wrong go wrong go wrong.
[Re: BobShaw]
#849792
12/02/07 06:33 PM
Ahh come on Automatic hubs work fine when they are working.
[Re: MadGary]
#849793
12/03/07 09:21 PM
I got a call from the Mitsu Dealership. They siad they think the hubs are damaged, and want to replace them. They want 650 bucks. Should I have em do it, or oder some superwinch hubs and do it myself? And if I do it myself, how hard is it?
[Re: MadGary]
#849794
12/03/07 09:32 PM
You can by them used for $30-60. More than likely they just need some lubricating. For one thing, both sides will not fail at the same time. You might want to post who your dealer is since they are dishonest and that will reduce the chance of others being raped by them.
[Re: MadGary]
#849795
12/03/07 09:43 PM
Unless you are way more mechanically inept than Stony <img src="/forums/images/graemlins/ignore.gif" alt="" />, you can defintely do this yourself. Please do as Charlie suggests and post the name of this Stealer.
[Re: hazy_daze]
#849796
12/03/07 09:47 PM
True dat! <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: stony-man]
#849797
12/03/07 10:08 PM
Sount Coast Mitsubishi, in Costa Mesa California.
[Re: MadGary]
#849798
12/03/07 10:10 PM
Is there a write up on how to replace em?
[Re: MadGary]
#849799
12/03/07 10:11 PM
Geez! I almost swallowed my tongue when I read that!
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
