Stereo Power Wires #850040 12/03/07 03:38 PM
O
OneLung Offline OP
I have a 93 YJ Sahara 4.0.
There is a JVC stereo/cd player in my dash. One of the wires say's 12vdc on it and goes directly to the battery. But the unit only works with the ignition turned on. Is there a change I can make so the stereo works without the ignition being on? I want to listen to my XM radio while outside the Jeep.
Thanks.
Re: Stereo Power Wires [Re: OneLung] #850041 12/03/07 04:20 PM
Bigbird79 Offline
There will be a wire marked switched 12 Volt + or something of the sort. If you wire this switched 12V and the constant 12 Volt + directly to the battery your stereo will work all the time. Just don't forget to turn your stereo off.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Stereo Power Wires [Re: Bigbird79] #850042 12/04/07 07:57 PM
Seattlegti Offline
The switched 12V is usually blue on aftermarket head units.
There might be a sticker on the bottom of your stereo that lists the color code for the wires.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5891 MB (Peak: 0.6420 MB) Data Comp: Off Server Time: 2026-06-12 10:42:24 UTC
