Well i looked up the repair manual online that Bombardj1 suggested, it did a good job of explaining how how it should have worked, but mine was not working that way. That repair manual what a great resourse, that for the link.
So here is what I did to fix the problem and it worked.
>Open the car door with the key, set the alarm off.
>Disarmed the alarm with the key in the ignition.
>Pulled the key out,
>Disconnected the positive post from the battery. Let it sit for about a half hour.
>Lock all 4 door buy pushing down on the locks. Then pulled up on all of them, so now they ere all unlocked again.
>After sitting for a half hour, reconnected the positive battery post. Keep the driver door open while doing this.
>Then push down on the door lock while the door is open to lock all the doors.
>Get out, and close the door. The Sportage should NOT give you a conformational 'armed' honk.
>To unlock, put your key in the door, turn left quickly. DO NOT turn the key right or it will arm the anti-theft.
>And whenever you need to lock it, just lock by pushing on the door lock from the inside while the door is open, then shut it. Don't use the key to lock it or the anti-theft will get re-armed.
All is well now. No issues. I want to thank Shaar from Kia-forums for most the door locking/unlocking procedure. I tried just the locking and unlocking procedure but it did not work by itÆs self, until I dis-connected the battery. One final thought, if I had just dis-connected the battery with out doing all the locking /unlocking procedure, that may have worked too, but I did not try it.
Thanks to everyone who help with this. I also hopes this will help others with the same issues.
Thanks again to everyone who helped Dan
2001 Kia Sportage 4x4 4dr Stock as of now other truck 2000 Ford F250 power stroke diesel 4x4, crew cab, long bed, 265/75/16, homemade tymar intake, zoodad mod, AIH mod, CCV mod, foil delete, coolant filter, Harpoon mod, pre pump mod, crossover
