Re: ABS Question [Re: eleet] #850794 12/08/07 09:15 PM
4
4xGeek Offline
Sure... I've read over on the 4Runner forum it's a relatively minor wire mod to disable (as it's disabled when the center locker engages). Still freaks me out on a regular basis though... Usually with her at the wheel & a truck coming.
Only time I've ever been appreciative of the on-board computer telling me what's what was on ice. It corrects nicely, even from a seemingly hopeless situation you just got yourself into. <img src="/forums/images/graemlins/lol.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: ABS Question [Re: 4xGeek] #850795 12/09/07 01:24 AM
E
eleet Offline
You mean they don't give you a button to shut it off??
97 T100 4x4
97 328i
95 540i restoration project
Re: ABS Question [Re: eleet] #850796 12/09/07 02:20 AM
4
4xGeek Offline
No shut-off on the '01 4Runner... Have they offered a bypass switch in newer ones?
4xGeek (Chris)
Re: ABS Question [Re: 4xGeek] #850797 12/09/07 03:11 PM
E
eleet Offline
I am not sure what toyota has been doing. But my cars, my friends cars, and cars i've rented all had a switch to shut off traction.
The button is either labeled with the name of the system (ASC, DSC, TRAC, whatever) or a "danger" icon with an ! in a triangle; except in the mustang where the icon depicted a skidding wheel.
Also on almost all of the cars I have seen a light come on the dash when a wheel slips and traction control does something. There's an indication when the system is turned off, too, either a 'trac off' light, or the same light that indicates operation burns steady.
Some of the systems work a little differently. The first time I felt it in a GM car, all it did was kick the throttle pedal back up at me (you could feel it in your right foot!) Modern ones like yours are built into the ABS, and the brain watches all four wheel-speeds. Sometimes there is a secondary throttle valve ahead of the main throttle body, that will close on traction operation. There is a signal that goes to the ECU to request that the engine timing be retarded. The brake lights come on while traction is operating. I have heard of some more advanced systems that have a set of accelerometers and steering angle sensor.
If you could get it to do selective braking without interfering with throttle, this might be golden. Sadly almost nobody gives the driver this option!
97 T100 4x4
97 328i
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6085 MB (Peak: 0.6636 MB) Data Comp: Off Server Time: 2026-06-07 02:27:54 UTC
