1991 will not start when cold, just happened yesterday #851006 12/08/07 03:47 PM
G
guzzilapd Offline OP
I have had NO previous cold starting problems. Yesterday morning after sitting all nite at 25 degrees I started the montero and within 30 seconds or less put it in R to back up. it stalled. I could not restart it. Put some gas line anti freeze in it. Still could not start. Just cranks and thats it.
I shot some ether into the air cleaner and got it started. Ran fine all day and starts right up when warm.
So, this morning I go to start it and the same thing happened. will start on ether but that is it.
Got to be something simple.
Help please so I dont have to keep using starting fluid!
freightdog727@yahoo.com
Scott
Re: 1991 will not start when cold, just happened yesterday [Re: guzzilapd] #851007 12/08/07 07:00 PM
G
generation_one Offline
well, have you checked around for loose wires and such?
get out your multi meter and read the K-ohms on the coolant sensor and air sensor...
The fuel pump and/or filter might be suspect.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: 1991 will not start when cold, just happened yesterday [Re: generation_one] #851008 12/09/07 04:23 PM
coolant sensor
x2
Re: 1991 will not start when cold, just happened yesterday [Re: fasteddy] #851009 12/10/07 08:58 PM
8
89IsMine Offline
coolant sensor
x2
So, I'm trying to think through how this works... To me it sounds like a fuel pump or regulator problem, because he states it will light off fine with starter fluid. Is the coolant temperature sensor inhibiting the fuel flow somehow? Obviously, I haven't gone and looked at the FSM manual yet to trace out the circuit <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
Re: 1991 will not start when cold, just happened yesterday [Re: 89IsMine] #851010 12/10/07 10:03 PM
G
yes it does ... the sensor bone is connected to the injector bone, sorta...
Might also be simply bad gasoline
My point was to get GP to help himself by posting some more info than "dang thing wont start"
If anyone has the "no start" link, that would be cool
Cant speak for FE's reasoning. He is one of those who are making their own computer control system...'nuff said about that.
about 200k miles
Re: 1991 will not start when cold, just happened yesterday [Re: generation_one] #851011 12/10/07 11:33 PM
8
89IsMine Offline
The caption for this claims it includes no-start and driveability...
1989 powertrain diagnostics
Eric W.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6115 MB (Peak: 0.6821 MB) Data Comp: Off Server Time: 2026-11-02 03:09:50 UTC
