Rating: 5
Page 4 of 78 1 2 3 4 5 6 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851147 04/24/08 06:59 PM
Red_Chili Offline
Toyota Section Staffer
Just checking in... glad to see you are not using the Downey headers after all. Mine has the ORS crossover, and was the prototype for his production unit (mine was version 1, then version 2. Version 2 is a keeper). It is worth it, very labor intensive and well made.
But it looks like you have the equivalent.
The 3.4 fit in my engine bay with the drivetrain 3" forward, with the stock hood, 1" body mount, and 2mm of clearance. <img src="/forums/images/graemlins/lol.gif" alt="" /> I elected to put in a scoop mostly for bling. Prior to the BL I ran a ventilated hood (hole <img src="/forums/images/graemlins/lol.gif" alt="" />) ). The firewall clearance was TIGHT until the BL. Much easier to fiddle with things now.
CHANGE THAT OIL PAN. You want a T100 2WD pan. Move the dipstick.
I used a FRORF crossmember, clean and strong, but not compatible with the chain tcase of course. I am running an R151 but frankly I'd run the stock R150 now with a V6 plate to get the Marlin Crawlers adapted. The R151 is bulletproof, but doesn't shift as nice.
Lookin' GOOD.
[edit] oh, and POR15 Metal Prep is basically the same pickling mentioned, just more expensive. It works.
-Bill
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Red_Chili] #851148 04/24/08 09:49 PM
Staceman Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Staceman] #851149 04/25/08 12:33 AM
CJM Offline OP
thanks guys ..
I really wanted the heat shield on the crossover .. as far as I can see .. so far i'm the only one whom has acomplished this ? smile
on ward and up ward ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851150 04/28/08 07:33 PM
Vanishing_Point Offline
I like your cross member. I have a similar idea with the trany mount.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Vanishing_Point] #851151 04/30/08 01:34 AM
CJM Offline OP
thanks ...
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851152 04/30/08 01:35 AM
CJM Offline OP
ok .. so a wee bit of work in the last couple of days ..
got the front calipers in and ohhh!! boy .. they need some work .
heres what I started with ..
got em' all "blasted" and cleaned
and then "zinc 'ed " ,
now ready for some Caliper paint , and NEW Toyota Pads ... I think I wanna fit the rims first .. so well see .
also started again on the rear diff .. got it out and started pullin' axles to get on the rear discs ..
and ordered parts .....
smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851153 05/02/08 05:45 AM
CJM Offline OP
so continueing on with the rear , I cut off all the brackets I dont want to use
and started to "test fit " the rear calipers and brackets ...
also making some new brakeline brackets
welded the nuts
and got them ready to weld on .
also got the new fan in today , so .. got the front lower rad support cut out , and fan mounted
test fit the grill
and made a NEW lower support ..
I still have to make the center support , and finish welding , but this will hold it together for now .
smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851154 05/03/08 01:34 AM
CJM Offline OP
so continueing on .... on the calipers .. a little detail .
some caliper paint .
and ready for new pads .
also .. put on the new tie rod ends ..
and got it all aligned , and "temporaly" installed
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851155 05/05/08 03:22 PM
Staceman Offline
Dang Cory, I need sunglasses to look at those calipers! Lookin good, keep 'em coming. What calipers are you gonna use on the rear axle?
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Staceman] #851156 05/05/08 04:07 PM
CJM Offline OP
smile thanks ..
rears are Caddy calipers with the emerg. leavers .. I'm just fuguring the cable , and mounts out for that , then I will POR the rear axle , and put the calipers in the same caliper paint .
rear discs are being "cut" right now , and I have ordered the front toyota pads , and rear bearings .. so i'm just waiting for those now .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.014s) Memory: 0.6585 MB (Peak: 0.7681 MB) Data Comp: Off Server Time: 2026-07-14 05:23:50 UTC
