Rating: 5
Page 6 of 78 1 2 … 4 5 6 7 8 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851167 05/14/08 08:45 AM
Vanishing_Point Offline
I see you like to use the zinc coat spray paint. Does that stuff hold up well to our northern winters?
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Vanishing_Point] #851168 05/14/08 03:47 PM
CJM Offline OP
it does ... it works very well . my winch bar on me DD came off of my /80 (bought NEW from warn industries in /80)
in the mid /90's when I sold the truck , I kept the winch and bar .. by that time it was really starting to rust .. so I sand blasted and zinc'd .. and painted ..
this is the same bar not even repainted .. but a new winch
here in 2007 . top bar is rusting from the inside out , but other then that .. it still looks great . this is the main reason I use it .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851169 05/14/08 09:00 PM
Red_Chili Offline
Toyota Section Staffer
What led you to want to use blocks of that height?
-Bill
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Red_Chili] #851170 05/15/08 12:51 AM
CJM Offline OP
space .. I need the space for the rear disc and emerg. leavers .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851171 05/15/08 12:58 AM
CJM Offline OP
so tacke'd up my hoops today ..
plumb bobbed , and leveled
also put the steering box in place .. to check clearances ..
connected up the drag link , and got it adjusted ..
all so I decided to brace the front hoops .. I have heard in some situations , they will tear right off the frame .. and I didnt want that .. so .. I'm also making some gussets , and will post em' up when i'm done .
thats about it .
smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851172 05/15/08 02:27 AM
Rauch_Off_Road Offline
Looks really good but I'm thinking you may regret the blocks especially with the 3.4. Why not do a Chevy swap using 1" or 2" lift springs? That way you could have a good ride and do away with the blocks. The way your building this truck its no problem to do it now rather then later.
(aka suprathepeg, aka Sean)
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Rauch_Off_Road] #851173 05/15/08 03:08 AM
CJM Offline OP
the blocks provide space for the emergency cables , and access to the caliper bolts , and adjustments .. as mentioned .. in this case , they are an asset
another build with out blocks
to close for my comfort , and there is NO room to adjust . to do any caliper "work" the axle must be dropped .. not smart in my books ..
on a personal note: I've ran blocks for 12 years in my 80 (pic'd above) .. 36" swampers , ARB's and 5:29's and kicker's .. I never had 1 issue .. not 1 .
I will run them again .
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851174 05/15/08 03:31 AM
matts Offline
Maybe you already indicated is, but where did you get your rear caliper brackets? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: sold the first one .. so this ones mine ... Trekker Build [Re: matts] #851175 05/15/08 03:27 PM
CJM Offline OP
there Sky's brackets .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851176 05/16/08 08:15 PM
Red_Chili Offline
the blocks provide space for the emergency cables , and access to the caliper bolts , and adjustments .. as mentioned .. in this case , they are an asset...
Granted, you need the room. Why not get the lift you need using springs/shackles of the proper lift? The rest of your rebuild/swap is of such high quality, it seems a shame not to.
-Bill
PHP: 7.4.33 Page Time: 0.025s Queries: 16 (0.021s) Memory: 0.6548 MB (Peak: 0.7777 MB) Data Comp: Off Server Time: 2026-10-29 03:09:59 UTC
